Pi Hole Apparently Not Set Up Correctly
Very new NOOB here, so apologies for a question that has already been asked multiple time, but in looking for past posts, I didn't really understand the solutions well enough to determine my problem.
Bottom line, using the CNN site, I am still seeing ads.
When I ssh to the Raspberry PI url, I get the following nslookup result, which I think indicates that everything is setup correctly?
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Mon Jan 6 13:57:49 2025 from 192.168.1.21
steve@raspberrypi:~ $ nslookup flurry.com
Server: fe80::2a80:88ff:fedc:455b%2%2
Address: fe80::2a80:88ff:fedc:455b%2#53
Address: 0.0.0.0
Address: ::
installed on a Zero 2W board, with Orbi Router.
I would anticipate not seeing ads in CNN.COM if this PI was working correctly
I see many ads on CNN.COM
https://tricorder.pi-hole.net/94ChTuo4/
Sounds like ads are leaking in via IPv6 DNS server(s) supplied by your router via "IPv6 Router Advertisement".
You should check what DNS server(s) is/are configured on the devices that are still showing ads.
If any of them isn't Pi-holed, ads will leak in especially bc IPv6 DNS is preferred over IPv4 DNS for most implementations.
