Pi hole and unbound on Debian 12
After a few hours I finally installed pi-hole on debian 12 with an apache server. Unfortunately, I cannot configure unbound to work. After entering pi-hole/dns/Custom 1 (IPv4) 127.0.0.1#5335 in the menu, dns does not respond. Ping by IP works, but after entering the domain name it no longer works. In the query log I have a servfail entry.
P.S. I use NetworkMenager for network configuration and do not have a /etc/resolve.conf file
Tools > Generate Debug Log
https://tricorder.pi-hole.net/LhB1wgM9/
Your debug log shows that Pi-hole is working properly. Now, let's take a look at unbound.
Is either unbound or Pi-hole running in a Docker container? Or, are they both running on bare metal?
Please post the output of the following command from the Pi terminal:
unbound-checkconf
They are installed directly in the Debian system.
/etc/unbound/unbound.conf.d/pi-hole.conf:    edns-buffer-size: 1232
/etc/unbound/unbound.conf.d/pi-hole.conf:    serve-expired: no
/etc/unbound/unbound.conf.d/pi-hole.conf:    prefetch: no
/etc/unbound/unbound.conf.d/remote-control.conf:remote-control:
/etc/unbound/unbound.conf.d/remote-control.conf:  control-enable: yes
/etc/unbound/unbound.conf.d/remote-control.conf:  control-interface: /run/unbound.ctl
unbound-checkconf: no errors in /etc/unbound/unbound.conf
With a clean install of Debian 12 you need to make sure systemd-resolved is installed to create a /etc/resolv.conf file. This isn't an issue If upgrading from Debian 11.
When systemd-resolved was running, pi-hole reported an error about port 535 being used by dnsmasq. Pihole-ftl did not start. After stopping systemd-resolved:
sudo systemctl stop systemd-resolved
sudo systemctl disable systemd-resolved
Pi-Hole started working without any problems
Unfortunately, I see that pi-hole + debian and apache create a lot of problems.
I gave up and uninstalled pi-hole. :frowning:
I didn't have such problems with another blocker.
