I have running on my pi the Pi-hole DNS and the ADS-B receiver. Well, because both use the lighttpd, and because other unknown issues, the Pi-hole admin webpage broke the Skyview map of the piaware (located at port :8080.
Well, someone on flightaware forums showed how to create an alternate local map of the planes using the ModeSMixer2. This shows a similar map, at port :8787 that works!
If anyone looks to install piaware with pi-hole, take a look there:
