Yes, there are two directories inside.
conf-available
conf-enabled
The conf-enabled folder has a file that is called "89-dump1090-fa.conf" that looks like this:
# Allows access to the static files that provide the dump1090 map view,
# and also to the dynamically-generated json parts that contain aircraft
# data and are periodically written by the dump1090 daemon.
alias.url += (
"/dump1090-fa/data/" => "/run/dump1090-fa/",
"/dump1090-fa/" => "/usr/share/dump1090-fa/html/"
# redirect the slash-less URL
url.redirect += (
"^/dump1090-fa$" => "/dump1090-fa/"
# Listen on port 8080 and serve the map there, too.
$SERVER["socket"] == ":8080" {
alias.url += (
"/data/" => "/run/dump1090-fa/",
"/" => "/usr/share/dump1090-fa/html/"
Then is another file called "15-fastcgi-php.conf":
# -*- depends: fastcgi -*-
# /usr/share/doc/lighttpd/fastcgi.txt.gz
# http://redmine.lighttpd.net/projects/lighttpd/wiki/Docs:ConfigurationOptions#mod_fastcgi-fastcgi
## Start an FastCGI server for php (needs the php5-cgi package)
fastcgi.server += ( ".php" =>
"bin-path" => "/usr/bin/php-cgi",
"socket" => "/var/run/lighttpd/php.socket",
"max-procs" => 1,
"bin-environment" => (
"PHP_FCGI_CHILDREN" => "4",
"PHP_FCGI_MAX_REQUESTS" => "10000"
"bin-copy-environment" => (
"PATH", "SHELL", "USER"
"broken-scriptfilename" => "enable"
# Add CORS header
server.modules += ( "mod_setenv" )
$HTTP["url"] =~ "^/dump1090-fa/data/.*\.json$" {
If you go to http://<PI>/dump1090-fa/ with the trailing slash, does it show you the Pi-hole dark page?
Yep, same page with or without trailing
Okay, try curl -I http://<PI>/dump1090-fa/ with and without the slash.
In SSH window?
HTTP/1.1 301 Moved Permanently
Date: Fri, 18 May 2018 01:28:29 GMT
Server: lighttpd/1.4.45
And the URL with the trailing slash?
HTTP/1.1 200 OK
Date: Fri, 18 May 2018 01:30:23 GMT
Hmm, that's what it should be doing for the PiAware to display, as a show of what the headers look like, try curl http://<PI> alone, it should show some X-Headers that say it's being served by Pi-hole.
pi@raspberrypi:/home $ curl -I http://127.0.0.1
HTTP/1.1 200 OK
Date: Fri, 18 May 2018 01:32:38 GMT
pi@raspberrypi:/home $ curl http://127:0.0.1
curl: (7) Couldn't connect to server
Had a couple of beers
pi@raspberrypi:/home $ curl http://127.0.0.1
<html><head>
<meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1"/>
<link rel='stylesheet' href='/pihole/blockingpage.css' type='text/css'/>
</head><body id='splashpage'><img src='/admin/img/logo.svg'/><br/>Pi-<b>hole</b>: Your black hole for Internet advertisements</body></html>
Heh, curl -I http://127.0.0.1/admin/ next.
pi@raspberrypi:/home $ curl -I http://127.0.0.1/admin/
HTTP/1.1 200 OK
X-Pi-hole: The Pi-hole Web interface is working!
X-Frame-Options: DENY
Set-Cookie: PHPSESSID=04r142otsubsap4ep1ro3je9j2; path=/
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate
Pragma: no-cache
Date: Fri, 18 May 2018 01:38:23 GMT
Those X-headers should only appear once, if they are there twice there is a loop somewhere that is probably contributing to the problem.
curl -I http://<PI>:8080/dump1090-fa/ since that is on a differnt port.
You like to make me type 127.0.0.1
pi@raspberrypi:/home $ curl -I http://127.0.0.1:8080/dump1090-fa/
HTTP/1.1 200 OK
Date: Fri, 18 May 2018 01:41:27 GMT
Last check curl http://127.0.0.1:8080/dump1090-fa/
pi@raspberrypi:/home $ curl http://127.0.0.1:8080/dump1090-fa/
[ERROR]: Unable to parse results from queryads.php: Unhandled error message (Invalid domain!)
One more check, it's verbose, but it will show the paths. curl -ILv http://127.0.0.1:8080/dump1090-fa/
pi@raspberrypi:/home $ curl -ILv http://127.0.0.1:8080/dump1090-fa/
- Trying 127.0.0.1...
- TCP_NODELAY set
- Connected to 127.0.0.1 (127.0.0.1) port 8080 (#0)
HEAD /dump1090-fa/ HTTP/1.1
Host: 127.0.0.1:8080
User-Agent: curl/7.52.1
Accept: /
< HTTP/1.1 200 OK
HTTP/1.1 200 OK
< Content-type: text/html; charset=UTF-8
< Date: Fri, 18 May 2018 01:56:31 GMT
< Server: lighttpd/1.4.45
- Curl_http_done: called premature == 0
- Connection #0 to host 127.0.0.1 left intact
There's no Pi-hole involvement in that. curl -Lv http://127.0.0.1/dump1090-fa/
