Nach einem Stromausfall läuft die Pi mit dem Phiole wieder. Nur ist jetzt das Problem das keine Seiten mehr erreichbar sind. An den Einstellungen wurde nichts geändert nach dem Stromausfall.
Update funktioniert ebenso nicht:
pi@raspberrypi:~ $ pihole -up
[i] Existing PHP installation detected : PHP version 7.4.28
[✓] Checking for git
[✓] Checking for iproute2
[✓] Checking for whiptail
[✓] Checking for ca-certificates
[i] Checking for updates...
fatal: konnte nicht auf 'https://github.com/pi-hole/pi-hole.git/' zugreifen: Could not resolve host: github.com
[i] Pi-hole Core: up to date
fatal: konnte nicht auf 'https://github.com/arevindh/AdminLTE/' zugreifen: Could not resolve host: github.com
[i] Web Interface: up to date
[i] FTL: update available
[i] FTL out of date, it will be updated by the installer.
[✓] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[✓] Checking apt-get for upgraded packages... 80 updates available
[i] It is recommended to update your OS after installing the Pi-hole!
[i] Checking for / installing Required dependencies for OS Check...
[✓] Checking for grep
[✓] Checking for dnsutils
[✗] Retrieval of supported OS list failed. dig failed with return code 10.
Unable to determine if the detected OS (Raspbian 11) is supported
Possible causes for this include:
- Firewall blocking certain DNS lookups from Pi-hole device
- ns1.pi-hole.net being blocked (required to obtain TXT record from versions.pi-hole.net containing supported operating systems)
- Other internet connectivity issues
https://docs.pi-hole.net/main/prerequesites/#supported-operating-systems
If you wish to attempt to continue anyway, you can try one of the following commands to skip this check:
e.g: If you are seeing this message on a fresh install, you can run:
curl -sSL https://install.pi-hole.net | sudo PIHOLE_SKIP_OS_CHECK=true bash
If you are seeing this message after having run pihole -up:
sudo PIHOLE_SKIP_OS_CHECK=true pihole -r
(In this case, your previous run of pihole -up will have already updated the local repository)
It is possible that the installation will still fail at this stage due to an unsupported configuration.
If that is the case, you can feel free to ask the community on Discourse with the Community Help category:
https://discourse.pi-hole.net/c/bugs-problems-issues/community-help/
Pi-Hole läuft mit unbound auf einem Raspberry
Das Debuglog kann ich auch nicht uploaden.
[✓] ** FINISHED DEBUGGING! **
* Error message: curl: (6) Could not resolve host: tricorder.pi-hole.net
* A local copy of the debug log can be found at: /var/log/pihole_debug.log
