If I run "ip-adress/admin" the pi-hole admin webpage should show instantly
It takes up to 5 minutes until the page will show. Login and usage is then fast as usuall. After a logout and waiting for 10 minutes I got the same behavior again. I got this issue since the last update to pi-hole version 3.1
Version
Pi-hole Version v3.1.4 Web Interface Version v3.1 FTL Version v2.10
I did update pihole to the most current stable version.
Any ideas?
Kind regards,
Christian
I run pi-hole on a rapsberry pi
pi@raspberrypi:~ $ cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 4 (v7l)
BogoMIPS : 38.40
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
I'm seeing a few errors in the lighttpd error log:
file_get_contents(https://api.github.com/repos/pi-hole/FTL/releases/latest): failed to open stream: Connection timed out in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 11
I think this could be the reason it's taking a while to load the page, as in the current version it is a blocking function.
You can try out the next version by running pihole checkout web devel (and pihole checkout web master to switch back) to see if the issue is resolved for you. Bear in mind the devel branch may be broken in other places, so it's probably best to switch back!
Looking at your debug log I can now see that you have api.github.com blacklisted (I missed this before! )
That domain needs to be accessible in order to get the versions, so unless you have another reason for blacklisting it, you can whitelist it by running pihole -w api.github.com (or using the web interface)
Thanks Mcat12 an PromoFaux regarding your quick help. In fact the issue has been solved by whitelisting api.github.com. Maybe I ask for a feature request, the needed url's cannot be blocked anymore? It would be great if an explanation will tell the user why the url will be needed and must not be blocked.
I'd rather not have hardcoded URLs that cannot be blacklisted, what is to say that we would not use it for any nefarious purpose? (Not that we ever would!)
