Pi-hole 6.x Not resolving local names while Pi-hole 5.x does
Im using PiHole 5 for long time and it resolves my local IPs correctly, however I can't make PiHole 6 do the same. I already tried installing Debian + PiHole 6 from scratch, tried importing hole configuration from PiHole 5 and also tried clean Pihole 6 with all settings provided manually (I only imported Adlists and white/balack lists from PiHole 5).
My setup looks looks like that:
  • router (OPNSense) 192.168.100.1 works as DNS and DHCP, on the DHCP side it is configured to use PiHole DNS (192.168.100.8).
  • PiHole is set to pass the requests to main DNS (router)
  • All clients communicate to PiHole and at that point all add lists are filtered, everything else should be (and on 5.x is) passed to router
One strange thing is that even without "Conditional forwarding" PiHole 6 is able to resolve my local network names on the "Query log" and lists, all my local devices are shown with their names regardless if i populate "Condidtional forwarding".
All nslookups from my PC to any devices on my network resolve as NXDOMAIN.
If this for some reason is intended on PiHole 6 I will be force to use PiHole 5 because duplicating DNS records to PiHole is not good idea (but it would probably work).
Pihole 5 and 6 is set up as an lxc container on Debian within Proxmox host. OPNsense router is a VM on the same Proxmox host.
Resolve my local network names by passing request to my router (DNS/DHCP)
Pi-Hole always responds with NXDOMAIN for all local domains (abc.lan), with exception of pihole itself (that is configured in local DNS records) and my router domain name (router.lan).
PiHole 5 = 6dGptH9Q
PiHole 6 = erjqJsAK
I saw exactly the same thing when I did the upgrade, nothing fancy here as Pi-Hole is the only thing running on my pair of Pi 3s running Raspberrian.
While the conditional forwarding is working I'd far prefer to not have to use it and just let pi-hole pass queries to my pfSense router for resolution as I did with v5.
