Pi hole 5 to 6 changes? How to restart DNS?
I used to edit custom.list then execute 'pihole restartdns' but apparently this changed from pihole 5 to 6? What is the comparable command now in pihole 6?
You can do this from the web admin GUI: Settings > System (in expert mode):
Or with the following command from the terminal:
sudo service pihole-FTL restart
Distributions with systemd may use sudo systemctl restart pihole-FTL instead of
This is no longer valid for the docker image, as systemctl/systemd are not available in the container.
Please also see my comment here: Restartdns not found - #12
Pi-hole image never used systemd.
Pi-hole v6 automatically reloads the configuration after any changes to pihole.toml.
Ok I referred to the last comment. Service is no longer available in the image
