The issue I am facing:
FTL goes to 100% cpu process and looses connection to API.
PHP error (2): fsockopen(): Unable to connect to 127.0.0.1:4711 (Connection refused) in /var/www/html/admin/scripts/pi-hole/php/FTL.php:47
Now it is the 4th time now.
Total queries over 1.3 million.
The only way to restore it is a fresh install and set it up again.
I deleted FTL database file and rebooted all is well but lost history.
Details about my system:
System ProLiant-DL360p-Gen8:~# lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 46 bits physical, 48 bits virtual
Byte Order: Little Endian
CPU(s): 24
On-line CPU(s) list: 0-23
Vendor ID: GenuineIntel
Model name: Intel(R) Xeon(R) CPU E5-2630 0 @ 2.30GHz
I have increased the DNS cache to 5 000 000 because the Yacy search engine fills the 10 000 to overflowing all the time.
The pihole has been busy most of the day with the log showing N/A as a reply from upstream servers.
