I just tried to install it on my Raspberry Pi400 with Ubuntu 20.04 and got the following error:
What can I do ?
What can I do ?
Did you install PHP8.0 intentionally? I'm running Pi-hole on Ubuntu 20.04 as well and my system uses PHP7.4. For which the required package is available.
Yes I did, because I run a Nextcloud on the same raspberry and they support it.
Well, we support it as well, however your system is missing a package that we need so your PHP8.0 installation is somewhat incomplete.
With PHP8.0, the JSON functionality is part of the core, so there exists no dedicated php8.0-json package. Ergo for PHP8 support, that package wound need to be removed from the dependency list, conditionally.
Shall I send a PR or do you think it's not worth it anymore, as of Pi-hole v6 with PH7?
Please do so. We don't know when v6.0 will arrive, yet and may be releasing an intermediate v5.x version in between.
PR up: Enable PHP8 support for Debian/Ubuntu by MichaIng · Pull Request #4135 · pi-hole/pi-hole · GitHub
Hey, I'm a little new to this. I am also getting the same error, that should i do, should i just wait?
My solution: go to /etc/.pihole/'automated install', then sudo nano basic-install.sh.
find and delet "${phpVer}-json" in PIHOLE_WEB_DEPS=(lighttpd "${phpVer}-common" "${phpVer}-cgi" "${phpVer}-${phpSqlite}" "${phpVer}-xml" "${phpVer}-json" "${phpVer}-intl")
save and exit, then ./basic-install.sh and your server should be uptodate
perfect, that does the trick. Also works with "pihole -up".
Yes, that fix needs to be applied manually until the local version has it included.
