I am experiencing a similar issue. Trying to run PiHole on Debian with the following docker-compose.yml file:
version: "3"
services:
pihole:
container_name: pihole
image: pihole/pihole:latest
# ports:
# - "53:53/tcp"
# - "53:53/udp"
# - "67:67/udp" # Only required if you are using Pi-hole as your DHCP server
# - "80:80/tcp"
environment:
TZ: 'Europe/Berlin'
PIHOLE_UID: 1000
PIHOLE_GID: 1000
WEBPASSWORD: '1234'
volumes:
- "/home/michael/homelab/docker/pihole:/etc/pihole"
- "/home/michael/homelab/docker/pihole:/etc/dnsmasq.d"
# https://github.com/pi-hole/docker-pi-hole#note-on-capabilities
cap_add:
- NET_ADMIN # Required if you are using Pi-hole as your DHCP server, else not needed
restart: unless-stopped
When doing a docker-compose up the process is being killed automatically and loops in a restart process indefinitely:
sudo docker-compose up
Pulling pihole (pihole/pihole:latest)...
latest: Pulling from pihole/pihole
42c077c10790: Pull complete
858cbeb930ec: Pull complete
4f4fb700ef54: Pull complete
01cae41a2fda: Pull complete
984b787b496f: Pull complete
c48dab7e362c: Pull complete
3a176fad8719: Pull complete
5dc7355bea16: Pull complete
3734d50778a6: Pull complete
Digest: sha256:f7624f452b7a6320405b6ff00a9ed253d99fd33a22abced1954633ceb5bae24e
Status: Downloaded newer image for pihole/pihole:latest
Creating pihole ... done
Attaching to pihole
pihole | [s6-init] making user provided files available at /var/run/s6/etc...exited 0.
pihole | [s6-init] ensuring user provided files have correct perms...exited 0.
pihole | [fix-attrs.d] applying ownership & permissions fixes...
pihole | [fix-attrs.d] 01-resolver-resolv: applying...
pihole | [fix-attrs.d] 01-resolver-resolv: exited 0.
pihole | [fix-attrs.d] done.
pihole | [cont-init.d] executing container initialization scripts...
pihole | [cont-init.d] 05-changer-uid-gid.sh: executing...
pihole | Changing ID for user: pihole (999 => 1000)
pihole | Changing ID for group: pihole (999 => 1000)
pihole | [cont-init.d] 05-changer-uid-gid.sh: exited 0.
pihole | [cont-init.d] 20-start.sh: executing...
pihole | ::: Starting docker specific checks & setup for docker pihole/pihole
pihole |
pihole | [i] Installing configs from /etc/.pihole...
pihole | [i] Existing dnsmasq.conf found... it is not a Pi-hole file, leaving alone!
[✓] Installed /etc/dnsmasq.d/01-pihole.conf
[✓] Installed /etc/dnsmasq.d/06-rfc6761.conf
pihole | Creating empty /etc/pihole/setupVars.conf file.
pihole | Configuring default DNS servers: 8.8.8.8, 8.8.4.4
pihole | ::: Assigning password defined by Environment Variable
pihole | [✓] New password set
pihole | DNSMasq binding to default interface: eth0
pihole | /opt/pihole/utils.sh: line 56: /etc/dnsmasq.d/01-pihole.conf: Permission denied
pihole | [cont-init.d] 20-start.sh: exited 1.
pihole | [cont-finish.d] executing container finish scripts...
pihole | [cont-finish.d] done.
pihole | [s6-finish] waiting for services.
pihole | [s6-finish] sending all processes the TERM signal.
pihole | [s6-finish] sending all processes the KILL signal and exiting.
The service volume path is a CIFS/SMB share which has been configured in /etc/fstab like:
//saturn/homelab /home/michael/homelab cifs username=xxx,password=xxx,uid=1000,gid=1000 0 0
The CIFS/SMB share is managed by TrueNAS with ACLs set up in a way that the group has full control.
When starting the deployment, I have noticed that the 01-pihole.conf file (which spawns a Permission denied above) has writing disabled:
ls -la
total 48
drwxr-xr-x 2 michael michael 0 Jul 17 12:24 .
drwxr-xr-x 2 michael michael 0 Jul 16 21:38 ..
-r-xr-xr-x 1 michael michael 1337 Jul 17 12:24 01-pihole.conf
-rwxr-xr-x 1 michael michael 2190 Jul 17 12:24 06-rfc6761.conf
-rwxr-xr-x 1 michael michael 0 Jul 17 12:09 custom.list
-rwxr-xr-x 1 michael michael 651 Jul 17 12:24 dns-servers.conf
-rwxr-xr-x 1 michael michael 1153 Jul 17 01:09 docker-compose.yml
-rwxr-xr-x 1 michael michael 20 Jul 16 20:36 environmetnvar
drwxr-xr-x 2 michael michael 0 Jul 16 22:03 etc
-rwxr-xr-x 1 michael michael 20 Jul 17 12:24 localbranches
-rwxr-xr-x 1 michael michael 43 Jul 17 12:24 localversions
-r-xr-xr-x 1 michael michael 132 Jul 17 12:24 pihole-FTL.conf
-r-xr-xr-x 1 michael michael 192 Jul 17 12:24 setupVars.conf
-rwxr-xr-x 1 michael michael 192 Jul 17 12:24 setupVars.conf.update.bak
Additionally, I have tried to set up the CIFS/SMB share directly within Docker like:
volumes:
homelab:
driver_opts:
type: cifs
device: "//saturn/homelab/docker/pihole"
o: "addr=saturn,username=xxx,password=xxx,uid=1000,gid=1000"
But it spawns the same 'Persmission Denied' error like above.
I am lost at this point and would appreciate any help.
