After a reboot or restart (pihole restartdns) everything works normally as expected, however after a period of time when I pull up the admin interface the section that shows the percentage Blocked blinks with 'Undefined%
Details about my system:
I am running the latest version of PiHole on a Raspberry Pi Desktop environment. Debian kernel with Jessie (?) desktop environment.
Quite literally nothing except system updates and upgrades.
Jessie has been unsupported for several years now.
You have some errors/abnormal entries in your logs:
-rw-r--r-- 1 pihole pihole 3022789 May 4 13:04 /var/log/pihole-FTL.log
[2021-05-04 00:00:05.242 8625/T8626] Client denied (at max capacity of 255): 321
[2021-05-04 00:00:05.242 8625/T8626] IPv4 telnet error: Success (0)
[2021-05-04 13:03:42.812 22096M] SQLite3 message: no such table: network in "SELECT hwaddr FROM network WHERE id = (SELECT network_id FROM network_addresses WHERE ip = ? GROUP BY ip HAVING max(lastSeen));" (1)
[2021-05-04 13:03:42.812 22096M] getMACfromIP("192.168.7.102") - SQL error prepare: SQL logic error
[2021-05-04 13:03:42.812 22096M] SQLite3 message: no such table: network_addresses in "SELECT name FROM network_addresses WHERE name IS NOT NULL AND ip = ?;" (1)
[2021-05-04 13:03:42.812 22096M] getNameFromIP("192.168.7.102") - SQL error prepare: SQL logic error
[2021-05-04 13:03:42.813 22096M] SQLite3 message: no such table: network in "SELECT interface FROM network JOIN network_addresses ON network_addresses.network_id = network.id WHERE network_addresses.ip = ? AND interface != 'N/A' AND interface IS NOT NULL;" (1)
[2021-05-04 13:03:42.813 22096M] getIfaceFromIP("192.168.7.102") - SQL error prepare: SQL logic error
[2021-05-04 13:03:42.814 22096M] SQLite3 message: no such table: network in "SELECT hwaddr FROM network WHERE id = (SELECT network_id FROM network_addresses WHERE ip = ? GROUP BY ip HAVING max(lastSeen));" (1)
[2021-05-04 13:03:42.814 22096M] getMACfromIP("192.168.7.102") - SQL error prepare: SQL logic error
[2021-05-04 13:03:42.815 22096M] SQLite3 message: no such table: network_addresses in "SELECT name FROM network_addresses WHERE name IS NOT NULL AND ip = ?;" (1)
[2021-05-04 13:03:59.802 22096M] SQLite3 message: no such table: network in "SELECT interface FROM network JOIN network_addresses ON network_addresses.network_id = network.id WHERE network_addresses.ip = ? AND interface != 'N/A' AND interface IS NOT NULL;" (1)
[2021-05-04 13:03:59.802 22096M] getIfaceFromIP("192.168.7.15") - SQL error prepare: SQL logic error
[2021-05-04 13:04:00.140 22096/T22100] SQLite3 message: no such table: network_addresses in "DELETE FROM network_addresses WHERE lastSeen < 1588619040;" (1)
[2021-05-04 13:04:00.140 22096/T22100] ERROR: SQL query "DELETE FROM network_addresses WHERE lastSeen < 1588619040;" failed: SQL logic error
[2021-05-04 13:04:00.140 22096/T22100] SQLite3 message: API call with invalid database connection pointer (21)
[2021-05-04 13:04:00.140 22096/T22100] SQLite3 message: misuse at line 165242 of [5d4c65779d] (21)
[2021-05-04 13:04:00.140 22096/T22100] Error while trying to close database: bad parameter or other API misuse
How much traffic is your Pi-hole seeing on a daily basis? Please post the output of the following run from the Pi terminal:
ls -lha /etc/pihole/pihole-FTL.db
sqlite3 /etc/pihole/pihole-FTL.db "SELECT value FROM counters WHERE id = 0"
It appears your long term database is corrupted. The filesize is zero, and the database doesn't have information that would be expected. Let's move the existing file and start a new one and see if the problem persists.
That looks like it fixed the issue, I let it do its thing during the night and checked this morning, information has populated and its no longer blinking.
Thank you very much!
If we can indulge just a bit further, what do you think caused the issue so that I can be proactive on it? Power loss? Anything like that?
