I have a Peloton Stationary Bike that connects to the live/pre recorded spin classes. When you login and connect to a class/session the video loads and you can begin your ride.
Ever since installing Pi-Hole connections to the video stream are too slow or will not connect at all. If I disable pi-hole everything works fine.
nu80pfqz6y
I'm sure there is a way, but i'm a newb at this. I know the static ip the peloton bike has, so there should be a way to view what url/addresses it is trying to connect to. How do I figure that out so I can white list it.?
