The issue I am facing:
Hi everyone, I'm having an issue implementing PiHole, computers keep losses connection with the Active directory once I impost the DNS of PiHole, it doesn't lose it immediately but after a restart of the PC.
I tried to setup a recrusive DNS, modifying the Host file and added the DNS of the Active Directory but nothing changed.
Any Ideas? Details about my system:
Pi-holev5.8.1 What I have changed since installing Pi-hole:
EDIT:
I see your Pi-hole's only upstream is at 192.168.9.199, and you also have enabled Conditional Forwarding to 192.168.9.1.
Presuming .199 to be your AD server and .1 to be your router, that would mean that your AD doesn't receive that fraction of DNS queries that you configured to be sent to your .1.
Depending on how your .1 further handles those requests, that may or may not interfere with your intended resolution of local names.
yes, you are correct, i want that the pc first looks for the DNS .199 (AD) and than the pihole dns, the point is that the PCs shouldn't lost the connection with the AD while using pihole dns to block/whitelist pages
How is your router currently configured to make use of Pi-hole?
For that to happen, you'd have to configure your AD to use Pi-hole as its only upstream DNS resolver, and your router to distribute your AD as local DNS server.
There should be no references to Pi-hole in your router.
Your DNS resolution chain would then look like this:
client AD Pi-hole public DNS resolver
This will only provide local names if your AD is actually aware of local names, which probably would require your AD to employ the equivalent of Pi-hole's Condtional Forwarding if your router would be handling DHCP.
It is unclear what host file you are referring to.
On Linux, /etc/hosts holds IP address to name associations - it is not involved in determining which DNS resolver is used.
If you manually configure your PC to use Pi-hole as DNS server, your resolution chain would be:
client Pi-hole public DNS resolver
