Pages to Test
On Pages to Test ad-blocking the site recommends testing two pages:
http://secure.quantserve.com/quant.js
https://secure.quantserve.com/quant.js
however, it doesn't give an example of what the user should expect, except to measure time between the two. however I have noticed once my devices are configure correctly, unsecured goes from showing a white page to a small text line, and the secure link goes from a refused connection, to a page with a lot of text (and obviously much faster).
Assuming this is the desired outcome, can we possibly describe the expected outcome with screen shots on the test page so users are more confident in their results.
On another note, Thank you to all who have helped and the metric ton of guides written on this page. it's been an awesome experience, I'm now DNSSEC verified, running the BETA, blocking HTTPS ads and unsecure ads across my entire network and even using my Pi as a DHCP instead of my router. If I can get all my traffic linked into my VPN, I'll be set.
I can understand what you mean. The response time is mainly what is of concern (less of a concern with FTLDNS), which is why those links are there. It should probably be moved to the end of the page after all the examples and could use a once over. I has assigned this to myself and I will take a look at making it clearer.
