Over 1000 DNS requests
hi.
i have some issue.
i get error report that says over 1000 DNS requests.
and this makes the whole system go down.
im thinking this is not a bad ide to seak help.
ore i will remove this, and have no DNS blocker
https://tricorder.pi-hole.net/1SE9sk3k/
Details about my system:
Change your rate limit:
Your debug log shows that your router at 192.168.0.1 gets rate limited.
This may happen if you'd have configured your router to use Pi-hole as its upstream, rather than telling your clients to use Pi-hole for DNS.
In that case, applying jfb's advice to adopt a rate limit according to your typical load would apply.
However, your debug log also suggests that there are indeed clients that send their DNS requests directly to your Pi-hole:
[✓] lighttpd daemon is active
*** [ DIAGNOSING ]: Pi-hole-FTL full status
   ● pihole-FTL.service - Pi-hole FTL
     Loaded: loaded (/etc/systemd/system/pihole-FTL.service; enabled; vendor preset: enabled)
     Active: active (running) since Wed 2023-10-04 12:16:28 UTC; 7h ago
Oct 04 12:16:32 rock-4c-plus pihole-FTL[539]: [2023-10-04 12:16:32.030 539M]  -> Unique clients: 13
How did you configure your router to make use of Pi-hole?
Hi.
thanks for replay. to both o you.
i have changed the rate limit. 2000/30
and i have configured the UDM PRO.
::: Under Network, select the default network and navigate to DHCP DNS Server. Set the DNS server to the IP address of your Pi-hole device. This will configure your UDM to assign the Pi-hole IP address as the DNS server for all devices that connect to your network via DHCP.
Under Internet, select the default WAN and navigate to DNS Server. Set the DNS server to the IP address of your Pi-hole device. This will configure your UDM to use the Pi-hole IP address as the DNS server for all outbound traffic.
like this from this link : UDM - PRO Link to reddit
i did this today.
if this work i will donate.
best reguard
Hi again, i don't know if someone read this ore not.
afther i did some changes.
i got a new Log entry.
Disk shortage (/var/log/pihole/FTL.log ) ahead: 91% used
help?
Please generate a new debug log and post the new token URL.
the new debug report
https://tricorder.pi-hole.net/L69QyFet/
its semms it works. somehow.
