Oracle CPQ to snowflake
I'm looking for some advice on how to extract data from Oracle CPQ to snowflake. I do not have any idea about how Oracle CPQ works and not sure on the data model how the system works. Is there any way we can extract Oracle CPQ transactional data into snowflake? I see rest API's can be used. But I want incremental data loads into snowflake for quotations that are created in Oracle CPQ.
Any help with suggestions or best practices to implement the incremental data pipeline from Oracle CPQ(Source) to Snowflake(Target) is greatly appreciated. Thanks!!
This is the Pi-hole forum.
Your issue does not involve Pi-hole or DNS at all.
You should consider consulting Oracle's documentation and support channels for assistance.
