Connect to internet through Pihole either on LAN or by VPN when outside
LAN connects well on internet through Pihole
when outside, I can connect to openVPN, I can ping the 2 addresses of Pihole, i.e 10.8.0.1 and 192.168.0.200, but I can't ping my server (192.168.0.254) neither any other LAN devices nor Internet.
I don't know what prevents me to ping outside the pihole.
here some info:
+++ from /etc/dhcpcd.conf
interface eth0
static ip_address=192.168.0.200/24
static routers=192.168.0.254
interface tun0
static ip_address=10.8.0.1/24
+++ route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.0.254 0.0.0.0 UG 202 0 0 eth0
10.8.0.0 0.0.0.0 255.255.255.0 U 0 0 0 tun0
192.168.0.0 0.0.0.0 255.255.255.0 U 202 0 0 eth0
+++ /etc/openvpn/server.conf
port 11942
proto udp
dev tun
sndbuf 0
rcvbuf 0
ca ca.crt
cert server.crt
key server.key
dh dh.pem
auth SHA512
tls-auth ta.key 0
topology subnet
server 10.8.0.0 255.255.255.0
ifconfig-pool-persist ipp.txt
push "redirect-gateway def1 bypass-dhcp"
push "dhcp-option DNS 10.8.0.1" #LAN IP of my router
push "route 192.168.0.0 255.255.255.0" #My LAN
keepalive 10 120
cipher AES-256-CBC
user nobody
group nogroup
persist-key
persist-tun
status openvpn-status.log
verb 3
crl-verify crl.pem
++++ sysctl -p /etc/sysctl.conf
net.ipv4.ip_forward = 1
++++ added /etc/dnsmasq.d/99-interfaces.conf
interface=tun0
interface=eth0
thanks for your help.
[twbfnqfet2]
