I have Pihole configured and it is blocking ads great. I have OpenDns as the Upstream server, but adult sites are not getting blocked. When I go to welcome.opendns.com and I get a saying I am using their service, but content is not getting filtered.
I have OpenDns 208.67.222.222 - 208.67.220.220 in the WAN section of Asus AC86U
LAN DNS in router, I have pointing to the pihole.
In Pihole, I have checked both IPV4 OpenDns Upstream servers
I can't figure it out why it's not working..please help.
As soon as I disconnect from Pihole, the OpenDns filtering starts working since I have it on the WAN.
I guess Pihole must not be forwarding DNS queries to OpenDns.
Your log shows pi-hole is working, forwarding queries to 208.67.222.222 and 208.67.220.220, and blocking domains.
You can check that reading your debug log using less /var/log/pihole/pihole.log and scrolling to the end of the file. Look for the -----tail of pihole.log------ section.
You can also verify the queries in real time:
using pihole -t on the command line or
accessing Tools > Tail pihole.log on the web interface.
That's how I have it. I have the Pihole DNS IP on the LAN DHCP section of the router.
This router does not accept unkown DNS servers in the WAN DHCP, so I can only use the LAN.
Pihole works and blocks ads as intended, but the content filtering from OpenDns is not working.
Since I couldn't get it to work, I started using Adguard, but before that I was testing different ways until I gave up. Maybe that debug I sent is showing one of the times I was messing with it.
I went back and setup Pihole like I had before and will run another debug.
If blank it's not working, you could try to use the same IP twice.
If it doesn't work too, try to add an unused IP from your network range (outside your DHCP range to avoid conflicts).
We always try to help, but we also like to teach users to find it's own solutions, when it's possible.
You can find the answer yourself, looking at your log:
you can generate and read the log on the command line;
you can generate and read the log on Web Interface;
you can use less /var/log/pihole/pihole.log to read the last generated debug log.
Thank you. I can read it, but that doesn't mean I will understand it enough to know what I need to do to fix it, lol. But I appreciate the help and time..thanks again.
Nice.. now, if I you allow a quick question on something related to pihole.. If I need to create a new thread let me know.
On my Asus router running Merlin's firmware, I use a few DNSmasq scripts to force SafeSearch network wise and it works well, but I notice once I point my computer to use Pihole's DNS, I lose the SafeSeach feature.
Is this what's supposed to happen or I should be able to run pihole and DnsMasq scripts enforced?
