One device is stuck in some kind of DHCP loop
The device should be connected to the network.
The device seems to be stuck in some kind of DHCP-loop. (This device got connected before I started to use pihole as DHCP and DNS)
https://tricorder.pi-hole.net/msvensubx0
This is coming to the log like every minute.
May 30 17:17:59 dnsmasq-dhcp[17070]: DHCPDISCOVER(enxb827eb6e0639) xx:xx:xx:xx:xx:xx
May 30 17:17:59 dnsmasq-dhcp[17070]: DHCPOFFER(enxb827eb6e0639) 192.168.1.65 xx:xx:xx:xx:xx:xx
May 30 17:17:59 dnsmasq-dhcp[17070]: DHCPREQUEST(enxb827eb6e0639) 192.168.1.65 xx:xx:xx:xx:xx:xx
May 30 17:17:59 dnsmasq-dhcp[17070]: DHCPACK(enxb827eb6e0639) 192.168.1.65 xx:xx:xx:xx:xx:xx 2508576D621051F0
So just this device doesn't likes the pihole DHCP for some reason.
Is the device a Google device?
No... It's an air purifier from Blueair. Blueair Classic 480i.
I managed to get it connected, I added it to the "Static DHCP leases configuration" in Pi-Hole and after that it got IP and got connected to the network.
It's still weird tough... So en explination why it didn't work with the IP the DHCP tought the device should have would be cool =) Or did the device just hate that IP. :smiley: The IP the DHCP would give the device from start was 192.168.1.65 but then I give it 192.168.1.40 in the static configuration and it worked.
Ok... This is very weird, I powered of the device because I was going to move it to another room and after that I got this DHCP-loop again, and when I from the web interface removed the static DHCP and saved so pihole-FTL restarted the device got the IP from the DHCP-pool, the one that it didn't want before and it got it this time. Well, then I had to power of the device again, and when it started it was stuck in the DHCP-loop, så I added it to the static DHCP conf again with the same static IP as before and saved to pihole-FTL restarted and it went fine and got that IP. So this seems to be an error every time the device is power cycled and connects to the DHCP-server.
I don't think this is a Pi-Hole issue. The issue appears to be with the client.
I've seen this before with different devices that do not acknowledge the DHCP packet properly.
In order to avoid any DHCP related issues, set a fixed IP on the device ...
@jfb
Depends on how you look on it... Before I changed to Pi-Hole as DHCP and DNS and used my Edgerouter-X as this, it worked just fine.
I can't set a fixed IP on this device... But after I change from static or not static so there is another IP-adress the DHCP packet is alright of some weird reason. :slight_smile:
The DHCP functionality of Pi-Hole is part of the embedded dnsmasq and is not written by the Pi-Hole developers.
I think I will open a ticket with Blueair, because all other devices doesn't have any problem.
How do I know what version of dnsmasq Pi-Hole is running in the FTL?
dig chaos txt version.bind +short
