First of all, thank you for looking at the debug log!
Then - my mistake, sorry!
The network configuration has changed due to our move a few weeks ago. The 192.168.x from the initial post is now 10.x.0.y. I still have the old config in my “fingers” when writing.
My networks are - in accordance with the debug log
- 10.1.0.0/24: Management for router, switch and access point
- 10.2.0.0/24: Office network
- 10.3.0.0/24: IoT
- 10.4.0.0/24: Guests
192.168.0.0/24 is a family location connected via S2S VPN.
Routing takes place here on the router, not on the pihole
The same applies to 192.168.1.0/24 and 192.168.2.0/24.
The S2S connections are always briefly offline due to the DSL forced disconnection.
The configure nics are:
enp0s31f6: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.2.0.199 netmask 255.255.255.0 broadcast 10.2.0.255
enp0s31f6.1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.1.0.2 netmask 255.255.255.0 broadcast 10.1.0.255
enp0s31f6.2: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.2.0.2 netmask 255.255.255.0 broadcast 10.2.0.255
enp0s31f6.3: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.3.0.2 netmask 255.255.255.0 broadcast 10.3.0.255
enp0s31f6.4: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.4.0.2 netmask 255.255.255.0 broadcast 10.4.0.255
enp0s31f6 is the default nic and route used. The nic is set to (reserverd) dhcp to be always available during the ip adress changes from the last weeks. When I use ntp with wildcard I get an ntp reply on just this interface but on none other.
Could the vlan tag assignment an issue?
Target Route Genmask Flags Metric Ref Use Iface
default _gateway 0.0.0.0 UG 0 0 0 enp0s31f6
10.1.0.0 0.0.0.0 255.255.255.0 U 0 0 0 enp0s31f6.1
10.2.0.0 0.0.0.0 255.255.255.0 U 0 0 0 enp0s31f6
10.2.0.0 0.0.0.0 255.255.255.0 U 0 0 0 enp0s31f6.2
10.3.0.0 0.0.0.0 255.255.255.0 U 0 0 0 enp0s31f6.3
10.4.0.0 0.0.0.0 255.255.255.0 U 0 0 0 enp0s31f6.4
link-local 0.0.0.0 255.255.0.0 U 1000 0 0 enp0s31f6
$ lsof -i:123
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
pihole-FT 44598 pihole 33u IPv4 1067467 0t0 UDP *:ntp
DNS service offered by pihole is reachable on all nics from all vlans.
BR Chris
