instead of lighttpd
-Fedora Linux 37
-Pi-Hole v5.15.5
-Spectrum router SAC2V2S
-Pi-Hole installs onto the OS. I'm able to log into the admin page. When I set the DNS on specific devices, they don't show up as clients on Pi-Hole.
I've gone through tutorials meticulously for HOURS. I made sure the Pi-Hole is set to a static IP. I cannot disable DHCP on the router and when I try to set a DNS on the router, it doesn't let me.
Help. Plz.
