Expecting the program to auto start when the computer boots up
Must be started manually
83xgv5nepv
I finally got things running on my Beaglebone Black and it works very well, except it will not automatically start on boot. I have to manually start pihole-FTL. Wondering if anyone can suggest a fix. I've tried pihole -r to no avail. Also, when I do run pihole -r, it changes the /etc/01-pihole.conf file and sets the cache-size=10000 which I have to comment out or nothing works. Any help would be greatly appreciated.
Thanks!
Ken
pihole -r will repair the install, and the /etc/pihole/01-pihole.conf is not supposed to be user edited, this file will be overwritten on repair or update. What is the problem you are seeing with the cache-size set? Does dnsmasq not start or give an error?
When I try running pihole-FTL with the cache--size set, I get this error:
dnsmasq: illegal repeated keyword at line 35 of /etc/dnsmasq.d/01-pihole.conf
I comment it out and everything seems to run smoothly.
I'll check out the init.d line and see what's going on.
That solved it! There was a file in the dnsmasq.d directory called SoftAp0 that I forgot gets installed on the Beaglebone Black. I cleared it out and pihole-FTL now starts as expected. Thank you!
