Not seeing logs in pihole dashboard
Not seeing any log entries in pihole dashboard
hey, thank you guys for devloping this amazing tool, installed on ubuntu 22.04 with check system os skipped and now it's loaded, but i notice there are number on the dashboard, and when i click in, there are no log entries. Pihole should be working, since i noticed diff when i open cnn.com before putting dns server as my server. what could be the issue here?
https://tricorder.pi-hole.net/HcTb8vAv/
Your router is giving out your ISP's DNS to clients to use for DNS, so they are almost certainly bypassing Pi-hole. The log shows Pi-hole is working if it is being used. Try the following test from a computer on your network which you think should be using Pi-hole.
Check what server it's using – only Pi-hole can resolve this special domain name
nslookup pi.hole
Check again, this time explicitly asking Pi-hole
nslookup pi.hole 10.0.0.219
Check if this domain is being blocked, it will be if Pi-hole is being used
nslookup flurry.com
Check again, once again explicitly asking Pi-hole
nslookup flurry.com 10.0.0.219
Thanks for replying,
In another mac using 10.0.0.219 as DNS, I ran
and it returns
Server:		10.0.0.219
Address:	10.0.0.219#53
Address: 10.0.0.219
i ran
it returns
Server:		10.0.0.219
Address: 0.0.0.0
so it should be working fine, but why can't i see the log entries in the dashboard of admin?
You're not seeing those, and other, lookups in Query Log when you reload the page? Is Settings > Privacy set to Show everything and record everything?
ah, my bad... I set it up as anoymous mode... my bad, now i am seeing them now. Thanks for helping
No worries, glad it's all working. Note you still need to fix that router DHCP so that it's giving out your Pi-hole IP instead of your two ISP DNS IPs. Or else clients using DHCP will bypass your Pi--hole.
