CSM
1
I'm getting "Not Secure" message when using HTTPS.
I've copied the Certificate from PiHole, and uploaded to Chrome, which shows the Cert as trusted.
What else do I need to check and setup to get the HTTPS to work without this message? I can still connect but it shows https with a line through it.
https://tricorder.pi-hole.net/YMj7xAkk/
Are you accessing using the IP or domain name?
What is exactly the URL you are using to access the web interface?
CSM
3
@rdwebdesign https://xx.xx.xx.xx:port/admin/login where xx=IP and port is number
The certificate was issued for a domain name (pi.hole), not for your IP.
Did you try using the domain https://pi.hole:8443/admin ?
Note:
You don't need to hide your local IP when you use a "Private IP range", like 192.168.0.0 - 192.168.255.255.
They are called private because they are not publicly accessible. Only devices from your local network can access them.
CSM
5
@rdwebdesign. That worked with the name. Wow, I didn't realize it wouldn't see the pi.hole and IP as same for the certificate.
Understood on the Private IP range.. Just habit I guess.
Just another note:
You don't need to mention me by name when you are answering my comments. We are already informed about every answer.
