I have a lot of block-lists, 539,196 domains,
I used to have no ad on IOS app, but recently I have some (Google ads) coming back for e.g on Speedtest app
it used to be block before so I'm guessing its could be a new domain used for ads or my system not using the good DNS. (I have a few AP but the primary DNS is set to Pi-pihole)
Also, I never been sure about the settings, I usually use my Pi Hole on the Network DNS settings (Modem + Router + AP) but internet settings have a different DNS option, I that ok to point to Pi Hole too or should you leave a external server e.g 1.1.1.1 or 8.8.8.8 ?
PS I noticed that when connecting to wifi with some device I have to manually enter a external DNS, if I leave the Pi Hole IP, the connection assistant won't let me save the settings (e.x for Samsung's TVs)
Block list
https://adblock.mahakala.is
https://hosts-file.net/exp.txt
https://hosts-file.net/emd.txt
https://hosts-file.net/psh.txt
https://www.malwaredomainlist.com/hostslist/hosts.txt
https://v.firebog.net/hosts/Airelle-hrsk.txt
https://v.firebog.net/hosts/Shalla-mal.txt
https://ransomwaretracker.abuse.ch/downloads/RW_DOMBL.txt
https://ransomwaretracker.abuse.ch/downloads/LY_C2_DOMBL.txt
https://ransomwaretracker.abuse.ch/downloads/CW_C2_DOMBL.txt
https://ransomwaretracker.abuse.ch/downloads/TC_C2_DOMBL.txt
https://ransomwaretracker.abuse.ch/downloads/TL_C2_DOMBL.txt
http://www.networksec.org/grabbho/block.txt
https://isc.sans.edu/feeds/suspiciousdomains_Medium.txt
http://someonewhocares.org/hosts/hosts
https://s3.amazonaws.com/lists.disconnect.me/simple_malvertising.txt
http://www.joewein.net/dl/bl/dom-bl.txt
https://raw.githubusercontent.com/ZeroDot1/CoinBlockerLists/master/hosts
https://raw.githubusercontent.com/crazy-max/WindowsSpyBlocker/master/data/hosts/win10/spy.txt
https://v.firebog.net/hosts/static/SamsungSmart.txt
https://v.firebog.net/hosts/Easyprivacy.txt
https://gist.githubusercontent.com/anudeepND/adac7982307fec6ee23605e281a57f1a/raw/5b8582b906a9497624c3f3187a49ebc23a9cf2fb/Test.txt
https://v.firebog.net/hosts/Easylist.txt
https://v.firebog.net/hosts/AdguardDNS.txt
https://blocklist.kowabit.de/list.txt
https://mirror.cedia.org.ec/malwaredomains/immortal_domains.txt
https://bitbucket.org/ethanr/dns-blacklists/raw/8575c9f96e5b4a1308f2f12394abd86d0927a4a0/bad_lists/Mandiant_APT1_Report_Appendix_D.txt
https://v.firebog.net/hosts/Prigent-Malware.txt
https://v.firebog.net/hosts/Prigent-Phishing.txt
https://raw.githubusercontent.com/quidsup/notrack/master/malicious-sites.txt
https://raw.githubusercontent.com/StevenBlack/hosts/master/data/add.Risk/hosts
http://v.firebog.net/hosts/Easylist.txt
https://gist.githubusercontent.com/elaur/a8f85175879562734946f9d00eee49aa/raw/65d001ab4f7b1c789c4ee066065ef0ef27eb3020/adlists.list
https://github.com/HenningVanRaumle/pihole-ytadblock
https://github.com/deathbybandaid/piadvanced/tree/master/piholetweaks/youtubeadblock
https://github.com/deathbybandaid/piadvanced/blob/master/piholetweaks/adguard.sh
https://github.com/deathbybandaid/piadvanced/blob/master/piholetweaks/parser.php
https://github.com/deathbybandaid/piadvanced/blob/master/piholetweaks/piholefreshlists.sh
https://raw.githubusercontent.com/deathbybandaid/wally3k-adlists.list/master/adlists.list
http://localhost/youtube-ads-list.txt
https://hosts-file.net/grm.txt
