Expecting to have much more than 5% ads blocked while using a lot of lists :
- Raspberry Pi OS 64bits
- Raspberry Pi 4
- Using dnscrypt-proxy
I'm currently having around 5% Ads blocked, a few months ago it was much much more with less ad lists, but I had to change ISP provider and my Sd Card for my RPI, so I did a fresh install and disabled DHCP from the provider's router and activated DHCP from Pi-hole, I also set the static IP's as it should, but I still get a lot of ads.
nslookup xp.apple.com
Server: 127.0.2.1
Address: 127.0.2.1#53
Non-authoritative answer:
xp.apple.com canonical name = xp.itunes-apple.com.akadns.net.
xp.itunes-apple.com.akadns.net canonical name = xp.apple.com.edgekey.net.
xp.apple.com.edgekey.net canonical name = e17437.dsct.akamaiedge.net.
Address: 92.122.148.85
Address: 2a02:26f0:b200:192::441d
Address: 2a02:26f0:b200:1bf::441d
Address: 2a02:26f0:b200:199::441d
tail -f /var/log/dnscrypt-proxy/query.log
[2023-03-20 11:15:49] 127.0.0.1 assets.raspberrypi.com HTTPS PASS 174ms dct-de1
[2023-03-20 11:15:49] 127.0.0.1 staging-assets.raspberrypi.com HTTPS PASS 188ms scaleway-fr
[2023-03-20 11:19:46] 127.0.0.1 mabbox.bytel.fr HTTPS PASS 0ms -
[2023-03-20 11:20:20] 127.0.0.1 api-mifit-de2.zepp.com A PASS 0ms -
[2023-03-20 11:20:26] 127.0.0.1 3.3.d.2.7.2.e.f.f.f.0.2.d.8.e.3.0.0.f.9.6.c.8.3.1.6.8.0.1.0.0.2.ip6.arpa PTR NXDOMAIN 1250ms dct-nl1
[2023-03-20 11:20:27] 127.0.0.1 6.5.6.a.d.9.8.9.2.9.3.0.6.b.5.e.0.0.f.9.6.c.8.3.1.6.8.0.1.0.0.2.ip6.arpa PTR NXDOMAIN 1743ms ams-doh-nl
[2023-03-20 11:20:35] 127.0.0.1 e.6.a.c.4.a.e.f.f.f.c.8.f.c.6.0.0.0.f.9.6.c.8.3.1.6.8.0.1.0.0.2.ip6.arpa PTR NXDOMAIN 1048ms dct-ru1
[2023-03-20 11:20:52] 127.0.0.1 mabbox.bytel.fr HTTPS PASS 0ms -
[2023-03-20 11:21:28] 127.0.0.1 xp.apple.com A PASS 19ms adguard-dns-unfiltered
[2023-03-20 11:21:28] 127.0.0.1 e17437.dsct.akamaiedge.net AAAA PASS 19ms ams-dnscrypt-nl
