alg42
June 20, 2022, 7:22pm
1
All porn sites included in blacklists and manually added in interface should be blocked.
-Pi Hole
-Raspberry Pi 3
Unifi equipment with a security gateway, two AP's and a switch all managed through the Windows Controller software.
Only blocking some sites mostly ad related. Should be blocking porn sites with two examples not being blocked as: www.pornhub.com and www.beeg.com
https://tricorder.pi-hole.net/WWkQD5XC/
From a client that you observe not blocking sites as expected, what is the output of the following commands:
nslookup pi.hole
nslookup flurry.com
nslookup www.beeg.com
jfb
June 20, 2022, 10:01pm
3
From the Pi terminal, what is the output of the following:
pihole -q www.pornhub.com
alg42
June 21, 2022, 2:53pm
4
The pihole -q www.pornhub.com showed me the problem. I'm not sure how or when but at some point I put (.|^)com$ into the whitelist.
All is well now.
jfb
June 21, 2022, 3:04pm
5
Unrelated observation from your debug log. You have a number of whitelist entries that are IP's, not domains. These are ineffective. If a client already has an IP, it won't request domain name resolution from Pi-hole. You can remove all these - example below
13.57.184.217
