Block ads, not nothing is being blocked.
I have a fresh Raspberry Pi OS (2020-05-27) installed and updated, running on a Raspberry Pi 3 B+. I have also followed the guides for installing Docker and Docker-Compose. I have only edited the time zone in the docker-compose.yml file and changed the DNS settings on the Arris SBG8300:
Gateway > Connection > Local IP Network > IPv4: Primary DNS 192.168.0.38 (static address of the Pi) and Secondary DNS is zeroed out. IPv6 for both primary and secondary are zeroed out as well.
Modem/Router setup: Arris SBG8300 (customer owned) > extended with TP-Link Archer A7. The Archer A7 is in "Access Point Mode" so should not be serving up DNS queries. Something is serving up DNS queries.
Pi is connected to the Archer A7 using WiFi and not using an Ethernet connection.
Running via docker-compose as a non-sudo user, but granted privileges via sudo usermod -aG docker your-user. Running the docker-compose up command from /home/ruser/Downloads/docker folder. Can access the admin portal via a web browser and can successfully log-in. The queries are not blocked and the stats show only one query blocked.
Noted these lines in the docker-compose.yml CLI response - not certain if this is anything:
pihole | [i] Installing configs from /etc/.pihole...
pihole | [i] Existing dnsmasq.conf found... it is not a Pi-hole file, leaving alone!
[✓] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf
pihole | chown: cannot access '': No such file or directory
pihole | chmod: cannot access '': No such file or directory
pihole | chown: cannot access '/etc/pihole/dhcp.leases': No such file or directory
Any assistance is greatly appreciated.
Not blocking ads and no changes in pi-hole statistics.
