Job for lighttpd.service failed because the control process exited with error code.
See "systemctl status lighttpd.service" and "journalctl -xe" for details.
root@linaro-alip:/etc/lighttpd# sudo systemctl status lighttpd.service
● lighttpd.service - Lighttpd Daemon
Loaded: loaded (/lib/systemd/system/lighttpd.service; enabled; vendor preset:
Active: failed (Result: exit-code) since Mon 2019-03-25 01:02:33 UTC; 2min 43
Process: 6890 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.co
Mar 25 01:02:33 linaro-alip systemd[1]: lighttpd.service: Start request repeated
Mar 25 01:02:33 linaro-alip systemd[1]: lighttpd.service: Failed with result 'ex
Mar 25 01:02:33 linaro-alip systemd[1]: Failed to start Lighttpd Daemon.
Support: https://www.debian.org/support
The unit lighttpd.service has entered the 'failed' state with result 'exit-co
Subject: A start job for unit lighttpd.service has failed
Defined-By: systemd
A start job for unit lighttpd.service has finished with a failure.
-- The job identifier is 5532 and the job result is failed.
Mar 25 01:03:24 linaro-alip sudo[6896]: linaro : TTY=pts/0 ; PWD=/etc/lighttpd
Mar 25 01:03:24 linaro-alip sudo[6896]: pam_unix(sudo:session): session opened f
Mar 25 01:03:26 linaro-alip sudo[6896]: pam_unix(sudo:session): session closed f
Mar 25 01:03:55 linaro-alip sudo[6921]: linaro : TTY=pts/0 ; PWD=/etc/lighttpd
Mar 25 01:03:55 linaro-alip sudo[6921]: pam_unix(sudo:session): session opened f
Mar 25 01:03:55 linaro-alip su[6922]: (to root) linaro on pts/0
Mar 25 01:03:55 linaro-alip su[6922]: pam_unix(su:session): session opened for u
Mar 25 01:05:17 linaro-alip sudo[6927]: root : TTY=pts/0 ; PWD=/etc/lighttpd
Mar 25 01:05:17 linaro-alip sudo[6927]: pam_unix(sudo:session): session opened f
Mar 25 01:05:29 linaro-alip sudo[6927]: pam_unix(sudo:session): session closed f
Mar 25 01:05:43 linaro-alip sudo[6930]: root : TTY=pts/0 ; PWD=/etc/lighttpd
Mar 25 01:05:43 linaro-alip sudo[6930]: pam_unix(sudo:session): session opened f
lines 2383-2405/2405 (END)
The unit lighttpd.service has entered the 'failed' state with result 'exit-code'.
Defined-By: systemd
Mar 25 01:03:24 linaro-alip sudo[6896]: linaro : TTY=pts/0 ; PWD=/etc/lighttpd ; USER=root ; COMMAND=/usr/sbin/service lighttpd stop
Mar 25 01:03:24 linaro-alip sudo[6896]: pam_unix(sudo:session): session opened for user root by linaro(uid=0)
Mar 25 01:03:26 linaro-alip sudo[6896]: pam_unix(sudo:session): session closed for user root
Mar 25 01:03:55 linaro-alip sudo[6921]: linaro : TTY=pts/0 ; PWD=/etc/lighttpd ; USER=root ; COMMAND=/bin/su
Mar 25 01:03:55 linaro-alip sudo[6921]: pam_unix(sudo:session): session opened for user root by linaro(uid=0)
Mar 25 01:03:55 linaro-alip su[6922]: pam_unix(su:session): session opened for user root by linaro(uid=0)
Mar 25 01:05:17 linaro-alip sudo[6927]: root : TTY=pts/0 ; PWD=/etc/lighttpd ; USER=root ; COMMAND=/bin/systemctl status lighttpd.service
Mar 25 01:05:17 linaro-alip sudo[6927]: pam_unix(sudo:session): session opened for user root by linaro(uid=0)
Mar 25 01:05:29 linaro-alip sudo[6927]: pam_unix(sudo:session): session closed for user root
Mar 25 01:05:43 linaro-alip sudo[6930]: root : TTY=pts/0 ; PWD=/etc/lighttpd ; USER=root ; COMMAND=/bin/journalctl -xe
Mar 25 01:05:43 linaro-alip sudo[6930]: pam_unix(sudo:session): session opened for user root by linaro(uid=0)
