The issue I am facing:
Not being able to access pihole web ui
Details about my system:
Docker
Latest version
using nginx proxy manager
the prefix to be /Pi-Hole/
Note: unable to access ui directry from 127.0.0.1 on host machine. docker container running in host network mode. error i get is to many redirects.
Debug Token: https://tricorder.pi-hole.net/H23cRT7g/
Can you please include your Compose file (or docker run
command) and the proxy configuration?
These files will help understand what is happening in your system.
pihole:
container_name: pihole
image: pihole/pihole:latest
network_mode: "host"
environment:
WEBPASSWORD: ${PI_HOLE_PASSWORD}
WEB_PORT: '1342'
volumes:
- './pihole:/etc/pihole'
- './pihole/dnsmasq.d:/etc/dnsmasq.d'
cap_add:
- NET_ADMIN
restart: unless-stopped
dockerproxy:
image: ghcr.io/tecnativa/docker-socket-proxy:latest
container_name: dockerproxy
environment:
- CONTAINERS=1 # Allow access to viewing containers
- SERVICES=1 # Allow access to viewing services (necessary when using Docker Swarm)
- TASKS=1 # Allow access to viewing tasks (necessary when using Docker Swarm)
- POST=0 # Disallow any POST operations (effectively read-only)
ports:
- 127.0.0.1:2375:2375
volumes:
- /var/run/docker.sock:/var/run/docker.sock:ro # Mounted as read-only
networks:
selfserv:
ipv4_address: 10.34.0.18
networks:
selfserv:
external: true
ipam:
config:
- subnet: 10.34.0.0/24
location /Pi-Hole/ {
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Scheme $scheme;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_set_header X-Forwarded-For $remote_addr;
proxy_set_header X-Real-IP $remote_addr;
proxy_pass http://192.168.0.34:1342/Pi-Hole/;
# Access Rules: 4 total
allow 172.18.0.0/24;
allow 10.34.0.0/24;
allow 192.168.0.0/24;
allow 94.174.102.24;
deny all;
# Access checks must...
satisfy any;
# Block Exploits
include conf.d/include/block-exploits.conf;
# Force SSL
include conf.d/include/force-ssl.conf;
# HSTS (ngx_http_headers_module is required) (63072000 seconds = 2 years)
add_header Strict-Transport-Security $hsts_header always;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $http_connection;
proxy_http_version 1.1;
https://tricorder.pi-hole.net/brkC74si/
^^ is the correct debug link
No aditional config. Im also unable to to acess via http://ip:port/Pi-Hole/
Update:
i have it working via url at http://mydomain.com/Pi-Hole/
just by adding
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Nginx-Proxy true;
rewrite ^/Pi-Hole/(.*)$ /$1 break;
into the "advanced" section of the custom location in nginx proxy manager. still cant access via ip and port though
system
Closed
5
