pihole version:
Core version is v6.0.5 (Latest: v6.0.5)
Web version is v6.0.2 (Latest: v6.0.2)
FTL version is v6.0.4 (Latest: v6.0.4)
Important notes:
I use tailscale but I don't need it here, so exclusively use my LAN IP
I have nextdns installed (listening on port 53 when up), but I performed a "sudo nextdns stop" and as far as I can see, port 53 is not in any conflict?
Your debug log shows NextDNS to be active on port 53, and Apache on port 80:
udp:0.0.0.0:51820 is in use by <unknown>
[✗] udp:127.0.0.1:53 is in use by nextdns (https://docs.pi-hole.net/main/prerequisites/#ports)
udp:0.0.0.0:123 is in use by pihole-FTL
udp:0.0.0.0:41641 is in use by tailscaled
udp:0.0.0.0:5353 is in use by avahi-daemon
udp:0.0.0.0:34351 is in use by avahi-daemon
udp:*:51820 is in use by <unknown>
[✗] udp:[::1]:53 is in use by nextdns (https://docs.pi-hole.net/main/prerequisites/#ports)
udp:*:123 is in use by pihole-FTL
udp:*:33149 is in use by avahi-daemon
udp:*:41641 is in use by tailscaled
udp:*:5353 is in use by avahi-daemon
[✓] tcp:0.0.0.0:443 is in use by pihole-FTL
tcp:127.0.0.1:631 is in use by cupsd
tcp:0.0.0.0:22 is in use by sshd
tcp:100.108.169.120:38392 is in use by tailscaled
[✗] tcp:127.0.0.1:53 is in use by nextdns (https://docs.pi-hole.net/main/prerequisites/#ports)
tcp:127.0.0.1:25 is in use by exim4
tcp:127.0.0.1:6010 is in use by sshd
tcp:[::1]:631 is in use by cupsd
tcp:[fd7a:115c:a1e0::4501:a978]:52619 is in use by tailscaled
tcp:[::1]:25 is in use by exim4
[✗] tcp:[::1]:53 is in use by nextdns (https://docs.pi-hole.net/main/prerequisites/#ports)
tcp:[::1]:6010 is in use by sshd
[✓] tcp:[::]:443 is in use by pihole-FTL
[✗] tcp:*:80 is in use by apache2 (https://docs.pi-hole.net/main/prerequisites/#ports)
tcp:[::]:22 is in use by sshd
You have to stop and disable your NextDNS DoH Proxy, so Pi-hole can bind to port 53 upon restart.
If you want to keep Apache, you have to move Pi-hole's embedded webserver to a different port, e.g. via CLI:
