Noob help. Dns error
i just installed pi-hole on windows with docker and im getting a DNSMASQ_WARN error. but everything seems to be working. i cant figure out how to resolve the error.
debug logs
https://tricorder.pi-hole.net/NcrOcymn/
image of error
(In this forum, you can paste images directly into a post.)
Your debug log shows your warning as:
*** [ DIAGNOSING ]: Pi-hole diagnosis messages
   id    timestamp            type                  message
   3     2022-04-14 05:58:25  DNSMASQ_WARN          ignoring nameserver 127.0.0.1 - local interface
The warning links to our documentation which reads:
At least one server directive is redundant and point to the dnsmasq instance itself. The server is ignored.
This is caused by your configuration of the loopback address as Pi-hole's upstream:
    PIHOLE_DNS_1=1.1.1.1
    PIHOLE_DNS_2=1.0.0.1
    PIHOLE_DNS_3=127.0.0.1
It doesn't cause any harms, but you still should remove that 127.0.0.1 from your Pi-hole's upstream servers at Settings | DNS.
