No web interface available refused to connect
Visiting the http://ipaddressofpihole/admin should display a admin interface when accessing from within the network OR 127.0.0.1/admin on localhost
I get an ERR_CONNECTION_REFUSED even when on the localhost.
https://tricorder.pi-hole.net/fnmsz8zgil
Note:
This is being ran on a Jetson Nano, no errors during install and I'm able to connect and use as a DNS source just fine.
Seems Pi-hole's web server lighttpd is not running:
[✗] lighttpd version could not be detected.
[✗] lighttpd daemon is failed
What's the output of the following commands;
which lighttpd
sudo systemctl status --full --no-pager lighttpd.service
brain@fart:~/Desktop/Docker/docker-pi-hole$ which lighttpd
/usr/sbin/lighttpd
brain@fart:~/Desktop/Docker/docker-pi-hole$ sudo systemctl status --full --no-pager lighttpd.service
● lighttpd.service - Lighttpd Daemon
   Loaded: loaded (/lib/systemd/system/lighttpd.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Wed 2021-02-24 14:47:20 EST; 2h 5min ago
  Process: 5279 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf (code=exited, status=127)
Feb 24 14:47:20 fart systemd[1]: lighttpd.service: Control process exited, code=exited status=127
Feb 24 14:47:20 fart systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Feb 24 14:47:20 fart systemd[1]: Failed to start Lighttpd Daemon.
Feb 24 14:47:20 fart systemd[1]: lighttpd.service: Service hold-off time over, scheduling restart.
Feb 24 14:47:20 fart systemd[1]: lighttpd.service: Scheduled restart job, restart counter is at 5.
Feb 24 14:47:20 fart systemd[1]: Stopped Lighttpd Daemon.
Feb 24 14:47:20 fart systemd[1]: lighttpd.service: Start request repeated too quickly.
Thanks to your help I found that I need to run 'apt-get install gamin' and apt-utils then I could start the lighttpd service.
Thanks again!
