pihole -v
Current Pi-hole version is development v4.3.5-492-ga1e913de.
Current AdminLTE version is devel v4.3.3.
Current FTL version is development vDev-da84864.
pihole -up
[i] Checking for updates...
fatal: unable to access 'https://github.com/pi-hole/pi-hole.git/': Could not resolve host: github.com
[i] Pi-hole Core: update available
fatal: unable to access 'https://github.com/pi-hole/AdminLTE.git/': Could not resolve host: github.com
[i] Web Interface: update available
curl: (6) Could not resolve host: ftl.pi-hole.net
[i] FTL: update available
[i] Pi-hole core files out of date, updating local repo.
[✓] Check for existing repository in /etc/.pihole
[i] Update repo in /etc/.pihole...
: Could not update local repository. Contact support.
pihole -r
and
[i] FTL Checks...
[✓] Detected ARM-hf architecture (armv6 or lower) Using ARM binary
[i] Checksums do not match, downloading from ftl.pi-hole.net.
[i] Downloading and Installing FTL...curl: (6) Could not resolve host: ftl.pi-hole.net
Error: URL https://ftl.pi-hole.net/development/pihole-FTL-arm-linux-gnueabi not found
[✗] FTL Engine not installed
pi@pihole02:~ $ pihole -v
Current Pi-hole version is development v5.0-38-gd524f9a7.
Current AdminLTE version is devel v5.0-101-g9c6a582c.
ftl offline no conection to api after pihole -r
[✗] pihole-FTL: no process found
[✓] Cleaning up stray matter
[✓] Restarting DNS server
[✗] DNS service is NOT running
Active: active (exited) since Wed 2020-05-13 16:56:47 CEST; 1min 35s ago
Process: 242 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
May 13 16:56:19 pihole02 systemd[1]: Starting LSB: pihole-FTL daemon...
May 13 16:56:21 pihole02 pihole-FTL[242]: Not running
May 13 16:56:24 pihole02 su[364]: (to pihole) root on none
May 13 16:56:24 pihole02 su[364]: pam_unix(su:session): session opened for user pihole by (uid=0)
May 13 16:56:46 pihole02 pihole-FTL[242]: Illegal instruction
May 13 16:56:47 pihole02 systemd[1]: Started LSB: pihole-FTL daemon.
pi@pihole02:~ $ sudo service pihole-FTL restart
pi@pihole02:~ $ sudo service pihole-FTL status
Active: active (exited) since Wed 2020-05-13 16:58:41 CEST; 2s ago
Process: 880 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
May 13 16:58:39 pihole02 systemd[1]: Starting LSB: pihole-FTL daemon...
May 13 16:58:39 pihole02 pihole-FTL[880]: Not running
May 13 16:58:39 pihole02 su[904]: (to pihole) root on none
May 13 16:58:39 pihole02 su[904]: pam_unix(su:session): session opened for user pihole by (uid=0)
May 13 16:58:41 pihole02 pihole-FTL[880]: Illegal instruction
May 13 16:58:41 pihole02 systemd[1]: Started LSB: pihole-FTL daemon.
