Hi Team,
No recording of activities, misfires ?
Kind regards,k0ns0l3
Could you elaborate on that?
Your screenshot shows well over 40,000 DNS queries.
Also, please upload a debug log and post just the token URL that is generated after the log is uploaded by running the following command from the Pi-hole host terminal:
Both screenshots show Pi-hole recorded every received query.
The gaps in the first graphic are not an indication of Pi-hole failure. They are an indication that your devices were not using Pi-hole during the gaps.
There are 2 possibilities:
I will check everything, thank you ![]()
