Hey, I assume I got 2 differents issues but lets get the basic information delivered first:
Setup: Raspberry Pi 5 with Debian which is running casa os and portainer. I manually setup pi-hole via portainer
Router: FritzBox 7590AX with Pi-hole setup as DNS-Server
Debug token:3dsTo8Ar
Even though I've worked with linux in the past this is the first time I'm setting up something in my local network so please excues my noob questions I've I have some.
After installing Pi-hole I noticed that my DNS resolution was unavalibe. As far as my knowledge goes I got that fixed. Now everything seems to be running fine (no error in the logs or when using pihole -g) except that issue with the Ipv6 adress and for the fact that nothing gets blocked. At this point I'm just puzzled and don't know where to continue.
Thanks for your help!
