Pi-Hole to distribute IP Addresses and block adds
PiZero W
Raspian Lite
ATX5400 Wi-Fi 6 Router
On Wed 11/17 internet went down in all of town. Up until this time Pi-Hole was working fine.
Wife got home at 730 and I got the notice that service had been restored. She turned on Nexflix and the network was working "fine". I had been running on mobile data, so hadn't noticed when it came back on. I turned on wifi and could not connect.
Opened the router and could not find the Pi0. power cycled everything, no luck. Unplugged Pi-Hole and everything started working, of course no add blocks. Messed with it for a while, then did a clean install of raspbian lite and pi-hole.
Still no luck getting pi-hole to block.
Raspian Lite fresh install, updated and upgraded.
pi-hole installed with curl -sSL https://install.pi-hole.net | bash
gave it a static IP of 192.168.0.2 enabled DHCP, set range to .3-.251
disabled router DHCP.
