Versions
- Pi-hole: v5.10
- AdminLTE: v5.12
- FTL: v5.15
Platform
- OS and version: Fedora Server 34
- Platform: Raspberry Pi 4b 2Gb RAM
Expected behavior
Enable DHCP on Pi-Hole, disable DHCP on my router, and everything just works.
When DHCP is enabled on Pi-Hole and disabled on my router (AT&T BGW320-500), devices are served IP addresses and DNS server just fine. The only problem is that the devices then are no longer connected to the internet. Pi-Hole is receiving the requests and supposedly answering them, yet no devices work. Connecting to the DNS manually while using the router's DHCP works great.
Steps to reproduce
- Install and set up Pi-Hole on Fedora Server 34
- Disable DHCP on router and enable in Pi-Hole
- Renew DHCP lease on computer/device (ipconfig /renew on Windows)
- Device loses internet connection
https://tricorder.pi-hole.net/O5P8vtNJ/
Additional context
- I initially installed Pi-Hole on Fedora Server 36 by bypassing the support checks and ran into no issues other than this one. Thinking that this might be the source of my problems I started from scratch with Fedora Server 34, which is officially supported, and ran into the same issue.
- My router does not support changing the DHCP's DNS even though it has a bunch of other advanced options. My theory on why is that ATT uses their own in-house DNS service to collect advertising data on their users so obviously they wouldn't want anybody circumventing that
Try releasing the lease. A renew would try to use the same leased address and the Pi-hole DHCP does not have any record of it.
Sorry, I should've clarified that I did that as well as flushing my DNS by running ipconfig /release and ipconfig /flushdns
Which IP address do the clients have? Do they have Pi-hole as the sole DNS server?
And please double check that you are using Pi-hole's DHCP. The debug log you provided does not have that enabled.
BLOCKING_ENABLED=true
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=192.168.1.204/24
IPV6_ADDRESS=2600:1700:9251:2690:decf:dff2:80eb:f6
PIHOLE_DNS_1=8.8.8.8
PIHOLE_DNS_2=8.8.4.4
QUERY_LOGGING=true
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=true
CACHE_SIZE=10000
DNS_FQDN_REQUIRED=true
DNS_BOGUS_PRIV=true
DNSMASQ_LISTENING=local
**DHCP_ACTIVE=false**
DHCP_START=192.168.1.201
DHCP_END=192.168.1.251
DHCP_ROUTER=192.168.1.1
DHCP_LEASETIME=24
PIHOLE_DOMAIN=lan
DHCP_IPv6=true
DHCP_rapid_commit=true
Oh sorry, the debug log was with it disabled. Here's the new one: https://tricorder.pi-hole.net/ysNCUzbK/
When running the debug with DHCP on, I noticed that it errored on the default gateway and provided a link to this. The website told me to set my default gateway to my router's default gateway. I have tried this before to no avail on Fedora Server 36 as it seemed to cause any DHCP request to time out. But I decided to try it again as I haven't tried it on Fedora Server 34 yet and I hadn't found anything that told me to set this to my router's default gateway until then (yes, I looked for probably half an hour and never found that site). And it seems to have worked! I have no idea if it not working before was due to being on Fedora 36 or from a configuration error, but it now works. I'm surprised that no one mentioned this in the numerous Pi-Hole DHCP tutorials I read. Thanks for the help!
