I'm running Pi-Hole on my Raspberry Pi 4 B with 2GB of RAM with the latest Raspberry Pi OS. I don't have access to my router's control page, so I use Pi-Hole putting my DNS on the devices I use in as my Pi's IP address. The expected behavior is Pi-Hole will connect just fine and I will get adblocking.
However, when I do this, I find that I have no internet. I also run OpenVPN through PiVPN on my Pi, and OpenVPN has the feature where if it detects Pi-Hole on a system, it will use it so you get adblocking while using the VPN, and when I connect through that, it works just fine.
_The debug token is this: https://tricorder.pi-hole.net/0OpLqDwd/
_
