no internet after installing pi hole and changing dns
stop ads and provide internet
after asking optimum to change DNS to the one pi-hole provided i no longer have internet access only access to pi-hole admin. However, if i change my computers dns to google it works. please help again no internet.
nothing
Were you able to generate a debug log, but it would not upload, or were you not able to generate a debug log?
hey thanks for the quick response
Edited by moderator to remove the debug log link - debug log has been made private for developer review.
Your debug log shows a few problems:
There are multiple IP addresses assigned to the Pi, and it's not clear which is currently in use. Also, the pi can't ping the default gateway and cannot reach the internet.
192.168.1.15/24 matches the IP found in /etc/pihole/setupVars.conf
192.168.17.0/24 does not match the IP found in /etc/pihole/setupVars.conf (https27)
  • Pinging 192.168.1.1...
    [✗] Gateway did not respond. (https)
[✗] Failed to resolve via localhost (127.0.0.1)
[✗] Failed to resolve via Pi-hole (192.168.1.15)
Your gravity list is empty:
-rw-r--r-- 1 root root 0 Dec 13 04:51 /etc/pihole/gravity.list
After you get the IP addresses on the Pi sorted and get it connected to the internet, then run pihole -r and select reconfigure to get the Pi listening on the correct interface and IP.
