Raspberry Pi v3.
Rasbian stretch 2018-04-18
Pihole working, but no info in web interface (all zero)
Debug log:
*** [ INITIALIZING ]
[i] 2018-07-10:14:13:47 debug log has been initialized.
[i] Core: v3.3.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v3.3.1-0-gfbee18e
[i] Web: v3.3 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v3.3-0-ge48aa29
[✓] FTL: v3.0
*** [ DIAGNOSING ]: dnsmasq version
[i] 2.76
[i] 1.4.45
[i] 7.0.30
[✓] Raspbian GNU/Linux 9 (stretch)
*** [ DIAGNOSING ]: SELinux
[✓] Default SELinux: permissive
[✓] Current SELinux: Disabled
*** [ DIAGNOSING ]: Processor
192.168.1.20/24 matches the IP found in /etc/pihole/setupVars.conf
fe80::9a3b:24f0:f9d6:eb6c does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
* Pinging 192.168.1.1...
[✓] Gateway responded.
[10000] is in use by miniserv.
[139] is in use by smbd
[] is in use by
[1883] is in use by mosquitto
[1885] is in use by mosquitto
[] is in use by
[22] is in use by sshd
[445] is in use by smbd
[53] is in use by dnsmasq
[5900] is in use by vncserver
[80] is in use by lighttpd
[3306] is in use by mysqld
[953] is in use by named
[✗] Failed to resolve anonymousproxy.tk via localhost (127.0.0.1)
[✓] anonymousproxy.tk is 89.108.104.205 via Pi-hole (192.168.1.20)
[✓] doubleclick.com is 216.58.201.142 via a remote, public DNS server (8.8.8.8)
[✓] dnsmasq daemon is active
[✓] lighttpd daemon is active
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=192.168.1.20/24
IPV6_ADDRESS=
PIHOLE_DNS_1=8.8.8.8
PIHOLE_DNS_2=8.8.4.4
QUERY_LOGGING=true
INSTALL_WEB=true
LIGHTTPD_ENABLED=1
[✗] X-Header does not match or could not be retrieved.
HTTP/1.1 200 OK
Date: Tue, 10 Jul 2018 14:14:04 GMT
Server: lighttpd/1.4.45
[✓] X-Pi-hole: The Pi-hole Web interface is working!
-rw-r--r-- 1 root root 4741692 Jul 10 13:56 /etc/pihole/gravity.list
192.168.1.20 0.0.0.0
192.168.1.20 0.r.msn.com
192.168.1.20 0.start.bz
192.168.1.20 000.0x1f4b0.com
192.168.1.20 zzz.clickbank.net
192.168.1.20 zzzezeroe.fr
192.168.1.20 zzzpooeaz-france.com
192.168.1.20 zzzrtrcm2.com
-rw-r--r-- 1 root root 633 Jul 7 16:27 /etc/pihole/adlists.list
-rw-r--r-- 1 root root 46 Jul 10 13:56 /etc/pihole/local.list
192.168.1.20 raspberrypi
192.168.1.20 pi.hole
-rw-r--r-- 1 root root 234 Jul 8 08:42 /etc/pihole/logrotate
/var/log/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-r--r-- 1 root root 1508 Jul 10 13:46 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries=extra
local-ttl=2
log-async
server=8.8.8.8
server=8.8.4.4
interface=eth0
-rw-r--r-- 1 root root 3027 Jul 8 08:42 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "pihole/index.php"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
"X-Frame-Options" => "DENY"
$HTTP["url"] =~ ".ttf$" {
url.access-deny = ("")
-rw-r--r-- 1 root root 1496 Jul 8 08:42 /etc/cron.d/pihole
54 4 * * 7 root PATH="$PATH:/usr/local/bin/" pihole updateGravity
00 00 * * * root PATH="$PATH:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker local
35 19 * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 555 Jul 10 14:08 /var/log/lighttpd/error.log
2018-07-07 17:03:28: (log.c.217) server started
2018-07-07 17:03:28: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2018-07-08 08:41:58: (server.c.1828) server stopped by UID = 0 PID = 1
2018-07-08 08:42:28: (log.c.217) server started
2018-07-08 08:42:28: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2018-07-10 14:08:47: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: parse_ini_file(/etc/pihole/pihole-FTL.conf): failed to open stream: No such file or directory in /var/www/html/admin/api_db.php on line 21
-rw-r--r-- 1 pihole pihole 3739 Jul 10 13:56 /var/log/pihole-FTL.log
[2018-07-10 13:47:54.574] FATAL: FTL received SIGTERM from PID/UID 11681/0, exiting gracefully
[2018-07-10 13:47:54.574] Shutting down...
[2018-07-10 13:47:54.592] Finished final database update
[2018-07-10 13:48:39.183]
[2018-07-10 13:48:39.183] FTL branch: v3.0
[2018-07-10 13:48:39.183] FTL version: v3.0
[2018-07-10 13:48:39.183] FTL commit: a1b2fa03f8f3e3713b57a26a4e9a062fec0573d7
[2018-07-10 13:48:39.183] FTL date: 2018-02-14 12:45:47 -0800
[2018-07-10 13:48:39.183] FTL user: pihole
[2018-07-10 13:48:39.183] Notice: Found no readable FTL config file
[2018-07-10 13:48:39.183] Using default settings
[2018-07-10 13:48:39.183] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2018-07-10 13:48:39.183] SOCKET_LISTENING: only local
[2018-07-10 13:48:39.183] QUERY_DISPLAY: Show queries
[2018-07-10 13:48:39.183] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2018-07-10 13:48:39.183] MAXDBDAYS: max age for stored queries is 365 days
[2018-07-10 13:48:39.184] RESOLVE_IPV6: Resolve IPv6 addresses
[2018-07-10 13:48:39.184] RESOLVE_IPV4: Resolve IPv4 addresses
[2018-07-10 13:48:39.184] DBINTERVAL: saving to DB file every minute
[2018-07-10 13:48:39.184] DBFILE: Using /etc/pihole/pihole-FTL.db
[2018-07-10 13:48:39.184] MAXLOGAGE: Importing up to 24.0 hours of log data
[2018-07-10 13:48:39.184] Finished config file parsing
[2018-07-10 13:48:39.189] Found no other running pihole-FTL process
[2018-07-10 13:48:39.190] PID of FTL process: 11769
-rw-r--r-- 1 dnsmasq root 325 Jul 10 13:56 /var/log/pihole.log
-----head of pihole.log------
Jul 10 13:56:33 dnsmasq[21190]: read /etc/hosts - 5 addresses
Jul 10 13:56:33 dnsmasq[21190]: read /etc/pihole/local.list - 2 addresses
Jul 10 13:56:33 dnsmasq[21190]: failed to load names from /etc/pihole/black.list: No such file or directory
Jul 10 13:56:35 dnsmasq[21190]: read /etc/pihole/gravity.list - 132702 addresses
[✓] ** FINISHED DEBUGGING! **
