Just installed PI hole on my RaspberryPi4 buster lite
Should have acces to the adminpanel at http://pi.hole/admin/
I have only acces to the adminpanel at the following address: http://192.168.178.30/admin
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations. This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected. Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2019-11-28:21:56:48 debug log has been initialized.
[i] Core: v4.3.2 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.3.2-0-ge41c4b5
[i] Web: v4.3.2 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.3.2-0-g38d8e77
[ā] FTL: v4.3.1
[i] 1.4.53
[i] 7.3.11
[ā] Raspbian GNU/Linux 10 (buster)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
[ā] armv7l
[ā] IPv4 address(es) bound to the eth0 interface:
192.168.178.30/24 matches the IP found in /etc/pihole/setupVars.conf
[ā] IPv6 address(es) bound to the eth0 interface:
fe80::dba3:6ae8:3354:f058 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[i] Default IPv4 gateway: 192.168.178.1
* Pinging 192.168.178.1...
[ā] Gateway responded.
*:3128 squid (IPv6)
*:22 sshd (IPv4)
*:22 sshd (IPv6)
*:3306 mysqld (IPv4)
[*:53] is in use by pihole-FTL
[127.0.0.1:4711] is in use by pihole-FTL
[[::1]:4711] is in use by pihole-FTL
[*:80] is in use by lighttpd
*:445 smbd (IPv6)
*:139 smbd (IPv6)
*:445 smbd (IPv4)
*:139 smbd (IPv4)
[ā] a2yglass.com.my is 0.0.0.0 via localhost (127.0.0.1)
[ā] a2yglass.com.my is 0.0.0.0 via Pi-hole (192.168.178.30)
[ā] doubleclick.com is 172.217.22.78 via a remote, public DNS server (8.8.8.8)
[ā] lighttpd daemon is failed
[ā] pihole-FTL daemon is active
BLOCKING_ENABLED=true
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=192.168.178.30/24
IPV6_ADDRESS=
PIHOLE_DNS_1=8.8.8.8
PIHOLE_DNS_2=8.8.4.4
QUERY_LOGGING=true
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=true
[ā] Block page X-Header: X-Header does not match or could not be retrieved.
HTTP/1.1 200 OK
Date: Thu, 28 Nov 2019 20:56:55 GMT
Server: Apache/2.4.38 (Raspbian)
Last-Modified: Fri, 15 Nov 2019 06:24:05 GMT
ETag: "29d2-5975ca50f6859"
Accept-Ranges: bytes
Content-Length: 10706
Vary: Accept-Encoding
Content-Type: text/html
[ā] Web interface X-Header: X-Header does not match or could not be retrieved.
HTTP/1.1 200 OK
Set-Cookie: PHPSESSID=n49mp0h062g5hv8flsao119mee; path=/
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate
Pragma: no-cache
Content-Type: text/html; charset=UTF-8
-rw-r--r-- 1 root root 2720132 Nov 28 21:49 /etc/pihole/gravity.list
0.0.0.0
0.nextyourcontent.com
0.r.msn.com
0.start.bz
zzz.clickbank.net
zzzezeroe.fr
zzzpooeaz-france.com
zzzrtrcm2.com
-rw-r--r-- 1 root root 313 Nov 28 21:48 /etc/pihole/adlists.list
-rw-r--r-- 1 root root 45 Nov 28 21:49 /etc/pihole/local.list
192.168.178.30 RasPi4
192.168.178.30 pi.hole
-rw-r--r-- 1 root root 234 Nov 28 21:49 /etc/pihole/logrotate
/var/log/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-r--r-- 1 root root 1387 Nov 28 21:49 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries
local-ttl=2
log-async
server=8.8.8.8
server=8.8.4.4
interface=eth0
-rw-r--r-- 1 root root 3499 Nov 28 21:49 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "/pihole/index.php"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
mimetype.assign = ( ".png" => "image/png",
".jpg" => "image/jpeg",
".jpeg" => "image/jpeg",
".html" => "text/html",
".js" => "application/javascript",
".json" => "application/json",
".txt" => "text/plain",
".svg" => "image/svg+xml" )
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
"X-Frame-Options" => "DENY"
$HTTP["url"] =~ ".ttf$" {
url.access-deny = ("")
-rw-r--r-- 1 root root 1703 Nov 28 21:49 /etc/cron.d/pihole
1 4 * * 7 root PATH="$PATH:/usr/local/bin/" pihole updateGravity >/var/log/pihole_updateGravity.log || cat /var/log/pihole_updateGravity.log
00 00 * * * root PATH="$PATH:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker local
52 19 * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 pihole pihole 13086 Nov 28 21:56 /var/log/pihole-FTL.log
[2019-11-28 21:46:51.095 4768] Using log file /var/log/pihole-FTL.log
[2019-11-28 21:46:51.095 4768] ########## FTL started! ##########
[2019-11-28 21:46:51.095 4768] FTL branch: master
[2019-11-28 21:46:51.095 4768] FTL version: v4.3.1
[2019-11-28 21:46:51.095 4768] FTL commit: b60d63f
[2019-11-28 21:46:51.095 4768] FTL date: 2019-05-25 21:37:26 +0200
[2019-11-28 21:46:51.095 4768] FTL user: pihole
[2019-11-28 21:46:51.095 4768] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-11-28 21:46:51.095 4768] SOCKET_LISTENING: only local
[2019-11-28 21:46:51.095 4768] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2019-11-28 21:46:51.095 4768] MAXDBDAYS: max age for stored queries is 365 days
[2019-11-28 21:46:51.095 4768] RESOLVE_IPV6: Resolve IPv6 addresses
[2019-11-28 21:46:51.095 4768] RESOLVE_IPV4: Resolve IPv4 addresses
[2019-11-28 21:46:51.095 4768] DBINTERVAL: saving to DB file every minute
[2019-11-28 21:46:51.096 4768] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-11-28 21:46:51.096 4768] MAXLOGAGE: Importing up to 24.0 hours of log data
[2019-11-28 21:46:51.096 4768] PRIVACYLEVEL: Set to 0
[2019-11-28 21:46:51.096 4768] IGNORE_LOCALHOST: Show queries from localhost
[2019-11-28 21:46:51.096 4768] BLOCKINGMODE: Null IPs for blocked domains
[2019-11-28 21:46:51.096 4768] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2019-11-28 21:46:51.096 4768] DBIMPORT: Importing history from database
[2019-11-28 21:46:51.096 4768] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-11-28 21:46:51.096 4768] PORTFILE: Using /var/run/pihole-FTL.port
[2019-11-28 21:46:51.096 4768] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-11-28 21:46:51.096 4768] WHITELISTFILE: Using /etc/pihole/whitelist.txt
[2019-11-28 21:46:51.096 4768] BLACKLISTFILE: Using /etc/pihole/black.list
[2019-11-28 21:46:51.096 4768] GRAVITYFILE: Using /etc/pihole/gravity.list
[2019-11-28 21:46:51.096 4768] REGEXLISTFILE: Using /etc/pihole/regex.list
[2019-11-28 21:46:51.096 4768] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2019-11-28 21:46:51.096 4768] AUDITLISTFILE: Using /etc/pihole/auditlog.list
[2019-11-28 21:46:51.096 4768] MACVENDORDB: Using /etc/pihole/macvendor.db
[2019-11-28 21:46:51.096 4768] PARSE_ARP_CACHE: Active
[2019-11-28 21:46:51.096 4768] Finished config file parsing
[2019-11-28 21:46:51.110 4768] SQLite3 message: cannot open file at line 38452 of [0eca3dd3d3] (14)
[2019-11-28 21:46:51.110 4768] SQLite3 message: os_unix.c:38452: (2) open(/etc/pihole/pihole-FTL.db) - (14)
[2019-11-28 21:55:41.563 740] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-11-28 21:55:41.563 740] PORTFILE: Using /var/run/pihole-FTL.port
[2019-11-28 21:55:41.563 740] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-11-28 21:55:41.563 740] WHITELISTFILE: Using /etc/pihole/whitelist.txt
[2019-11-28 21:55:41.563 740] BLACKLISTFILE: Using /etc/pihole/black.list
[2019-11-28 21:55:41.563 740] GRAVITYFILE: Using /etc/pihole/gravity.list
[2019-11-28 21:55:41.563 740] REGEXLISTFILE: Using /etc/pihole/regex.list
[2019-11-28 21:55:41.563 740] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2019-11-28 21:55:41.563 740] AUDITLISTFILE: Using /etc/pihole/auditlog.list
[2019-11-28 21:55:41.563 740] MACVENDORDB: Using /etc/pihole/macvendor.db
[2019-11-28 21:55:41.563 740] PARSE_ARP_CACHE: Active
[2019-11-28 21:55:41.563 740] Finished config file parsing
[2019-11-28 21:55:41.607 740] Database version is 3
[2019-11-28 21:55:41.607 740] Database successfully initialized
[2019-11-28 21:55:41.609 740] New forward server: 8.8.4.4 (0/512)
[2019-11-28 21:55:41.610 740] Imported 69 queries from the long-term database
[2019-11-28 21:55:41.610 740] -> Total DNS queries: 69
[2019-11-28 21:55:41.610 740] -> Cached DNS queries: 24
[2019-11-28 21:55:41.610 740] -> Forwarded DNS queries: 45
[2019-11-28 21:55:41.610 740] -> Exactly blocked DNS queries: 0
[2019-11-28 21:55:41.611 740] -> Unknown DNS queries: 0
[2019-11-28 21:55:41.611 740] -> Unique domains: 16
[2019-11-28 21:55:41.611 740] -> Unique clients: 1
[2019-11-28 21:55:41.611 740] -> Known forward destinations: 1
[2019-11-28 21:55:41.611 740] Successfully accessed setupVars.conf
[2019-11-28 21:55:41.634 743] PID of FTL process: 743
[2019-11-28 21:55:41.635 743] Listening on port 4711 for incoming IPv4 telnet connections
[2019-11-28 21:55:41.636 743] Listening on port 4711 for incoming IPv6 telnet connections
[2019-11-28 21:55:41.637 743] Listening on Unix socket
[2019-11-28 21:55:41.647 743] Received SIGHUP, reloading cache
[2019-11-28 21:55:41.647 743] Blocking status is enabled
[2019-11-28 21:55:41.647 743] INFO: No whitelist file found
[2019-11-28 21:55:41.647 743] Compiled 0 Regex filters and 0 whitelisted domains in 0.3 msec (0 errors)
[2019-11-28 21:55:42.632 743] /etc/pihole/gravity.list: parsed 116818 domains (took 975.8 ms)
[2019-11-28 21:56:10.678 743] New forward server: 8.8.8.8 (1/512)
*** [ DIAGNOSING ]: contents of /dev/shm
-rw------- 1 pihole pihole 323584 Nov 28 21:55 /dev/shm/FTL-clients
-rw------- 1 pihole pihole 108 Nov 28 21:55 /dev/shm/FTL-counters
-rw------- 1 pihole pihole 65536 Nov 28 21:55 /dev/shm/FTL-domains
-rw------- 1 pihole pihole 12288 Nov 28 21:55 /dev/shm/FTL-forwarded
-rw------- 1 pihole pihole 28 Nov 28 21:55 /dev/shm/FTL-lock
-rw------- 1 pihole pihole 53248 Nov 28 21:55 /dev/shm/FTL-overTime
-rw------- 1 pihole pihole 196608 Nov 28 21:56 /dev/shm/FTL-queries
-rw------- 1 pihole pihole 12 Nov 28 21:55 /dev/shm/FTL-settings
-rw------- 1 pihole pihole 4096 Nov 28 21:55 /dev/shm/FTL-strings
-rw------- 1 proxy proxy 8 Nov 28 21:55 /dev/shm/squid-cf__metadata.shm
-rw------- 1 proxy proxy 8216 Nov 28 21:55 /dev/shm/squid-cf__queues.shm
-rw------- 1 proxy proxy 36 Nov 28 21:55 /dev/shm/squid-cf__readers.shm
*** [ DIAGNOSING ]: Locale
LANG=C
-rw-r--r-- 1 pihole pihole 27181 Nov 28 21:57 /var/log/pihole.log
-----head of pihole.log------
Nov 28 21:46:51 dnsmasq[4773]: started, version pi-hole-2.80 cachesize 10000
Nov 28 21:46:51 dnsmasq[4773]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset auth DNSSEC loop-detect inotify dumpfile
Nov 28 21:46:51 dnsmasq[4773]: using nameserver 8.8.4.4#53
Nov 28 21:46:51 dnsmasq[4773]: using nameserver 8.8.8.8#53
Nov 28 21:46:51 dnsmasq[4773]: read /etc/hosts - 5 addresses
Nov 28 21:46:51 dnsmasq[4773]: failed to load names from /etc/pihole/local.list: No such file or directory
Nov 28 21:46:51 dnsmasq[4773]: failed to load names from /etc/pihole/black.list: No such file or directory
Nov 28 21:46:51 dnsmasq[4773]: failed to load names from /etc/pihole/gravity.list: No such file or directory
Nov 28 21:46:51 dnsmasq[4773]: query[AAAA] raw.githubusercontent.com from 127.0.0.1
Nov 28 21:46:51 dnsmasq[4773]: forwarded raw.githubusercontent.com to 8.8.4.4
Nov 28 21:46:51 dnsmasq[4773]: forwarded raw.githubusercontent.com to 8.8.8.8
Nov 28 21:46:51 dnsmasq[4773]: reply raw.githubusercontent.com is <CNAME>
Nov 28 21:46:51 dnsmasq[4773]: reply github.map.fastly.net is NODATA-IPv6
Nov 28 21:46:51 dnsmasq[4773]: query[A] raw.githubusercontent.com from 127.0.0.1
Nov 28 21:46:51 dnsmasq[4773]: cached raw.githubusercontent.com is <CNAME>
Nov 28 21:46:51 dnsmasq[4773]: reply github.map.fastly.net is 151.101.0.133
Nov 28 21:46:51 dnsmasq[4773]: reply github.map.fastly.net is 151.101.64.133
Nov 28 21:46:51 dnsmasq[4773]: reply github.map.fastly.net is 151.101.128.133
[ā] ** FINISHED DEBUGGING! **
* For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
* If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
[ā] Your debug token is: https://tricorder.pi-hole.net/b0bcegsc1t
* Provide the token above to the Pi-hole team for assistance at
* https://discourse.pi-hole.net
* Your log will self-destruct on our server after 48 hours.
* A local copy of the debug log can be found at: /var/log/pihole_debug.log
