New PiHole installation - nothing seems to be working. Issue with Blocking and Unbound
Installed PiHole years ago following the tutorial, never had any issues.
Moved, formatted my SD, reinstalled Raspberry Pi OS, proceeded to install PiHole.
Expectation: PiHole works and Unbound works.
When I installed PiHole there were no issues, however it did not seem to block anything. I figured it's an issue with the DNS server so I installed Unbound as I had it before.
During the Unbound installation I kept getting this error:
Reading package lists... Done
Building dependency tree... Done
unbound
0 upgraded, 1 newly installed, 0 to remove and 1 not upgraded.
Need to get 808 kB of archives.
After this operation, 4,344 kB of additional disk space will be used.
Get:1 Index of /raspbian bookworm/main armhf unbound armhf 1.17.1-2+deb12u2 [808 kB]
Fetched 808 kB in 1s (687 kB/s)
Selecting previously unselected package unbound.
(Reading database ... 160471 files and directories currently installed.)
Preparing to unpack .../unbound_1.17.1-2+deb12u2_armhf.deb ...
Unpacking unbound (1.17.1-2+deb12u2) ...
Setting up unbound (1.17.1-2+deb12u2) ...
Could not execute systemctl: at /usr/bin/deb-systemd-invoke line 145.
Processing triggers for man-db (2.11.2-2) ...
Hoped it would fix install but when I run "sudo service unbound restart" I get this error:
Job for unbound.service failed because the control process exited with error code.
See "systemctl status unbound.service" and "journalctl -xeu unbound.service" for details.
"systemctl status unbound.service" spits out:
unbound.service - Unbound DNS server
Loaded: loaded (/lib/systemd/system/unbound.service; enabled; preset: enab>
Active: failed (Result: exit-code) since Sat 2024-05-04 22:06:50 PDT; 7min>
Docs: man:unbound(8)
Process: 2101 ExecStartPre=/usr/libexec/unbound-helper chroot_setup (code=e>
Process: 2103 ExecStartPre=/usr/libexec/unbound-helper root_trust_anchor_up>
Process: 2105 ExecStart=/usr/sbin/unbound -d -p $DAEMON_OPTS (code=exited, >
Process: 2106 ExecStopPost=/usr/libexec/unbound-helper chroot_teardown (cod>
Main PID: 2105 (code=exited, status=1/FAILURE)
CPU: 327ms
May 04 22:06:50 raspberrypi systemd[1]: unbound.service: Failed with result 'ex>
May 04 22:06:50 raspberrypi systemd[1]: Failed to start unbound.service - Unbou>
May 04 22:06:50 raspberrypi systemd[1]: unbound.service: Scheduled restart job,>
May 04 22:06:50 raspberrypi systemd[1]: Stopped unbound.service - Unbound DNS s>
May 04 22:06:50 raspberrypi systemd[1]: unbound.service: Start request repeated>
lines 1-18
I uninstalled and reinstalled Unbound multiple times trying to fix it, but nothing worked.
Please go easy on me, I'm not great with this.
Thank you in advance.
[https://tricorder.pi-hole.net/sti5W7vp/]
