Hi, I don't no why exactly, but my different attempts results to get the newest release.
Current Pi-hole version is v3.3-420-gb2fb3fd
Current AdminLTE version is v3.2.1-300-g97967f6
Current FTL version is vDev-8e56b61
one new issue:
Here my log what I did today:
ZBOX ~ # rm /etc/pihole/ftlbranch
ZBOX ~ # pihole checkout master
Please note that changing branches severely alters your Pi-hole subsystems
Features that work on the master branch, may not on a development branch
This feature is NOT supported unless a Pi-hole developer explicitly asks!
Have you read and understood this? [y/N] y
[i] Shortcut "master" detected - checking out master branches...
[i] Pi-hole core
[β] Switching to branch: 'master' from 'refs/heads/release/v4.0'
[i] Already up-to-date.
[i] Web interface
[β] Switching to branch: 'master' from 'refs/heads/master'
[β] Detected x86_64 architecture
[i] Running installer to upgrade your installation
[β] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[i] Performing unattended setup, no whiptail dialogs will be displayed
[β] Disk space check
[β] Update local cache of available packages
[β] Checking apt-get for upgraded packages... up to date!
[β] Checking for apt-utils
[β] Checking for dialog
[β] Checking for debconf
[β] Checking for dhcpcd5
[β] Checking for git
[β] Checking for iproute2
[β] Checking for whiptail
[β] Check for existing repository in /etc/.pihole
[β] Update repo in /etc/.pihole
[β] Check for existing repository in /var/www/html/admin
[β] Update repo in /var/www/html/admin
[i] Main Dependency checks...
[β] Checking for bc
[β] Checking for cron
[β] Checking for curl
[β] Checking for dnsmasq
[β] Checking for dnsutils
[β] Checking for iputils-ping
[β] Checking for lsof
[β] Checking for netcat
[β] Checking for sudo
[β] Checking for unzip
[β] Checking for wget
[β] Checking for idn2
[β] Checking for sqlite3
[β] Checking for lighttpd
[β] Checking for php-common
[β] Checking for php-cgi
[β] Checking for php-sqlite3
[β] Installing scripts from /etc/.pihole
[β] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf
[i] Creating log and changing owner to dnsmasq... log already exists!
[i] Installing blocking page...
[β] Creating directory for blocking page, and copying files
[β] Backing up index.lighttpd.html
[β] Installing sudoer file
[β] Installing latest Cron script
[β] Installing latest logrotate script
[i] FTL Checks...
[i] Downloading and Installing FTL.../tmp/tmp.Pm3m5HALba /etc/.pihole
transferred... /etc/.pihole
[β] Downloading and Installing FTL
[i] Restarting services...
[β] Starting dnsmasq service
[β] Enabling dnsmasq service to start on reboot
[β] Starting lighttpd service
[β] Enabling lighttpd service to start on reboot
[β] Starting pihole-FTL service
[β] Enabling pihole-FTL service to start on reboot
[i] Preparing to run gravity.sh to refresh hosts...
[i] Cleaning up previous install (preserving whitelist/blacklist)
[i] Running gravity.sh
[β] DNS resolution is currently unavailable
[β] DNS resolution is now available
[β] Pulling blocklist source list into range
[i] Target: raw.githubusercontent.com (hosts)
[β] Status: Retrieval successful
[i] Target: mirror1.malwaredomains.com (justdomains)
[i] Target: sysctl.org (hosts)
[i] Target: zeustracker.abuse.ch (blocklist.php?download=domainblocklist)
[i] Target: s3.amazonaws.com (simple_tracking.txt)
[i] Target: s3.amazonaws.com (simple_ad.txt)
[i] Target: v.firebog.net (Kowabit.txt)
[i] Target: raw.githubusercontent.com (pi_blocklist_porn_top1m.list)
[i] Target: github.com (pi_blocklist_porn_all.list)
[i] Target: raw.githubusercontent.com (malicious-sites.txt)
[i] Target: raw.githubusercontent.com (trackers.txt)
[i] Target: v.firebog.net (AdguardDNS.txt)
[i] Target: v.firebog.net (Easylist.txt)
[i] Target: v.firebog.net (Easyprivacy.txt)
[i] Target: v.firebog.net (Shalla-mal.txt)
[i] Target: easylist-downloads.adblockplus.org (easylistgermany.txt)
[i] Format: Adblockcomm: file 1 is not in sorted order
[β] Format: Adblock
[i] Target: easylist-downloads.adblockplus.org (fanboy-annoyance.txt)
[β] Format: Adblock
[i] Target: raw.githubusercontent.com (ytadblock.txt)
[i] Target: dehakkelaar.nl (cryptojacking_campaign.list.txt)
[i] Target: raw.githubusercontent.com (appads.txt)
[i] Target: raw.githubusercontent.com (cryptomine.txt)
[i] Target: raw.githubusercontent.com (nomsdata.txt)
[β] Consolidating blocklists
[β] Extracting domains from blocklists
[i] Number of domains being pulled in by gravity: 2093039
[β] Removing duplicate domains
[i] Number of unique domains trapped in the Event Horizon: 1953391
[i] Number of whitelisted domains: 107
[i] Number of blacklisted domains: 36
[β] Parsing domains into hosts format
[β] Cleaning up stray matter
[β] Force-reloading DNS service
[β] DNS service is running
[β] Pi-hole blocking is Enabled
Error: Unable to complete update, please contact support
ZBOX ~ # pihole -up
[i] Checking for updates...
[i] Pi-hole Core: up to date
[i] FTL: up to date
[i] Web Interface: up to date
[β] Everything is up to date!
ZBOX ~ # pihole -r
[β] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[i] Repair option selected
[i] Performing reconfiguration, skipping download of local repos
[β] Resetting repository within /etc/.pihole...
[β] Resetting repository within /var/www/html/admin...
[β] Checking for bc
[i] FTL Checks...
[i] Latest FTL Binary already installed (v3.0). Confirming Checksum...
[i] Checksum correct. No need to download!
[β] Format: Adblock
[β] Format: Adblock
ZBOX ~ # echo βFTLDNSβ | sudo tee /etc/pihole/ftlbranch
βFTLDNSβ
ZBOX ~ # pihole checkout core FTLDNS
[i] Branch change has been cancelled
ZBOX ~ # pihole checkout core FTLDNS -x
[β] Fetching branches from https://github.com/pi-hole/pi-hole.git
[i] 33 branches available for Pi-hole Core
[β] Switching to branch: 'FTLDNS' from 'refs/heads/master'
[β] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[i] Existing PHP installation detected : PHP version 7.0.30-0ubuntu0.16.04.1
[β] Checking for bc
[β] Checking for psmisc
[β] Checking for libcap2-bin
[β] Checking for dns-root-data
[β] Checking for resolvconf
[β] Checking for php7.0-common
[β] Checking for php7.0-cgi
[β] Checking for php7.0-sqlite3
[i] FTL Checks...
[i] Downloading and Installing FTL...curl: (22) The requested URL returned error: 404 Not Found
Error: URL not found
[β] FTL Engine not installed
[β] man pages installed and database updated
[i] Systemd-resolved is not enabled
[β] Deleting existing list cache
[β] Format: Adblock
[β] Format: Adblock
[i] Number of regex filters: 0
[i] The install log is located at: /etc/pihole/install.log
Update Complete!
Current Pi-hole version is v3.3-414-g169a428
Current AdminLTE version is v3.3
Current FTL version is v3.0
ZBOX ~ # pihole checkout FTLDNS -x
[i] Requested option "FTLDNS" is not available
ZBOX ~ # nano /etc/resolv.conf
ZBOX ~ #
[β] Switching to branch: 'FTLDNS' from 'refs/heads/FTLDNS'
[β] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[β] Checking for bc
[i] FTL Checks...
[β] Format: Adblock
[β] Format: Adblock
Update Complete!
ZBOX ~ # /etc/.pihole/automated\ install/basic-install.sh --skip-DNS-port-check
[β] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[i] Update option selected
[β] Checking for bc
[i] FTL Checks...
[β] Format: Adblock
[β] Format: Adblock
Update Complete!
ZBOX ~ # release/v4.0 | sudo tee /etc/pihole/ftlbranch
-bash: release/v4.0: No such file or directory
ZBOX ~ # pihole checkout core release/v4.0
ZBOX ~ # pihole checkout core release/v4.0 -x
[β] Switching to branch: 'release/v4.0' from 'refs/heads/FTLDNS'
Updating a44096a..b2fb3fd
Fast-forward
advanced/{ => Templates}/logrotate | 0
advanced/Templates/pihole-FTL.conf | 84 +++++++++++++++++++++++++++++
advanced/{ => Templates}/pihole-FTL.service | 0
advanced/{ => Templates}/pihole.cron | 0
advanced/{ => Templates}/pihole.sudo | 0
automated install/basic-install.sh | 23 ++++----
6 files changed, 98 insertions(+), 9 deletions(-)
rename advanced/{ => Templates}/logrotate (100%)
create mode 100644 advanced/Templates/pihole-FTL.conf
rename advanced/{ => Templates}/pihole-FTL.service (100%)
rename advanced/{ => Templates}/pihole.cron (100%)
rename advanced/{ => Templates}/pihole.sudo (100%)
[β] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[β] Checking for bc
[i] FTL Checks...
[β] Format: Adblock
[β] Format: Adblock
Update Complete!
[β] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[β] Checking for bc
[i] FTL Checks...
[β] Format: Adblock
[β] Format: Adblock
Update Complete!
ZBOX ~ # pihole checkout web release/v4.0
[β] Fetching branches from https://github.com/pi-hole/AdminLTE.git
[i] 16 branches available for Web Admin
[β] Switching to branch: 'release/v4.0' from 'refs/heads/master'
ZBOX ~ # pihole -r
[β] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[β] Checking for bc
[i] FTL Checks...
[β] Format: Adblock
[β] Format: Adblock
Update Complete!
ZBOX ~ # pihole uninstall
[?] Are you sure you would like to remove Pi-hole? [y/N] y
[β] Root user check
[i] Be sure to confirm if any dependencies should not be removed
[i] The following dependencies may have been added by the Pi-hole install:
apt-utils dialog debconf dhcpcd5 git iproute2 whiptail bc cron curl dnsutils iputils-ping lsof netcat psmisc sudo unzip wget idn2 sqlite3 libcap2-bin dns-root-data resolvconf lighttpd php7.0-common php7.0-cgi php7.0-sqlite3
[?] Do you wish to go through each dependency for removal? (Choosing No will leave all dependencies installed) [Y/n] n^C
ZBOX ~ # pihole -up
[i] FTL: update available
[i] FTL out of date, it will be updated by the installer.
[β] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[β] Checking for bc
[i] FTL Checks...
[β] Format: Adblock
[β] Format: Adblock
Update Complete!
ZBOX ~ # pihole -up
[β] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[β] Checking for bc
[i] FTL Checks...
[β] Format: Adblock
[β] Format: Adblock
Update Complete!
βFTLDNSβ
ZBOX ~ # echo release/v4.0 | sudo tee /etc/pihole/ftlbranch
release/v4.0
[β] Switching to branch: 'release/v4.0' from 'refs/heads/release/v4.0'
[β] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[β] Checking for bc
[i] FTL Checks...
[i] FTL can now resolve DNS Queries without dnsmasq running separately
[β] Stopping dnsmasq service...
[β] Disabling dnsmasq service
[β] Format: Adblock
[β] Format: Adblock
Update Complete!
