New install of Pi-Hole running in a Docker Container does not allow Gravity to update
Please help...I'm cross eyed!
Two days and no progress. I cannot see the problem and I do not know how to run the gravity db using the command line in a docker. I doubt the command line update would help.
Pi-Hole is the only thing I am running on a new Raspberry Pi 5, running the Raspberry Pi OS lite (64 bit) OS. I have sudo apt update && sudo apt upgrade -y several times today. I have started from scratch reinstalling the OS using the Raspberry Pi Imager v1.8.5 three times today.
The Raspberry is connected to the router by ethernet. I connect to it wirelessly.
I have rebooted the ASUS RT-AX82U Router (192.168.50.1) multiple times and have always had good internet connectivity via Google Fiber.
I have removed the docker container (docker rm --force pihole) and rerun the docker-compose.yml (docker-compose up -d), file included below, six or seven times in the past two days.
I can ssh into the Raspberry Pi 5 (192.168.50.226) and navigate around in it.
I can access the web interface for the Pi-Hole (192.168.50.245/admin).
I can ping the block list address and google.com from within the Pi-Hole directory.
The block lists have been Teleport/Import from a Pi 3B running Pi-Hole (no docker) without error. I have also removed block lists and reentered them manually.
Pi-Hole running in a Docker Container does not allow Gravity to update, sample is below (there are nine block lists total, only showing one for brevity):
[i] Neutrino emissions detected... [βœ“] Pulling blocklist source list into range
[βœ“] Preparing new gravity database
[βœ“] Creating new gravity databases
[i] Using libz compression
[βœ—] Status: Connection Refused
[βœ—] List download failed: no cached list available
[βœ“] Building tree
[βœ“] Swapping databases
[βœ“] The old database remains available
[i] Number of gravity domains: 0 (0 unique domains)
[i] Number of exact blacklisted domains: 39
[i] Number of regex blacklist filters: 0
[i] Number of exact whitelisted domains: 293
[i] Number of regex whitelist filters: 8
[βœ“] Cleaning up stray matter
[βœ“] FTL is listening on port 53
[βœ“] UDP (IPv4)
[βœ“] TCP (IPv4)
[βœ“] UDP (IPv6)
[βœ“] TCP (IPv6)
[βœ“] Pi-hole blocking is enabled
This is my docker-compse.yml file:
services:
  pihole:
    container_name: pihole
    image: pihole/pihole:latest
      networks:
      pihole_network:
        ipv4_address: '192.168.50.245'
    ports:
      - "53:53/tcp"
      - "53:53/udp"
      #- "67:67/udp" # Only required if you are using Pi-hole as your DHCP server
      - "80:80/tcp"
    environment:
      TZ: 'America/New_York ' # update according to your timezone
      WEBPASSWORD: 'password'
    volumes:
      - '/home/piledhigh/pihole/etc-pihole:/etc/pihole'
      - '/home/piledhigh/pihole/etc-dnsmasq.d:/etc/dnsmasq.d'
    cap_add:
      - NET_ADMIN
    restart: unless-stopped
networks:
  pihole_network:
    driver: macvlan
    driver_opts:
      parent: eth0 # eth0 will need to be replaced by name of your ethernet network interface
    ipam:
      config:
        - subnet: 192.168.50.0/24
          gateway: 192.168.50.1
Taken, with modification, from the Ultimate Raspberry Pi Server: Pi-Hole with Docker Compose on YouTube.
I’m exhausted, been chasing my tail around for two days.
Please throw this dog a bone…any help will be gratefully appreciated.
CraigM
I'm glad to hear that I'm not the only one went sideways for a few days ago. This lines up with when I lost mine with docker. Watching for updates.
I would suggest installing using the offical guide via the pihole github. Seems to be some differences. I've only played around with the docker images but using the guide on a 4B I had no issues OTB.
This is the real issue.
Your container is not able to access the Internet to download the lists.
Without a debug log is not possible to understand exactly what is causing the connection issue, but macvlan is an advanced network mode.
By default (without creating a special network interface), this mode doesn't allow communication between host and container, which usually causes connection issues.
If Pi-hole is the only thing running on the machine, why did you choose to use a macvlan network?
The default network mode (bridge) is usually simpler and, since you are not running other services, you probably don't need an IP for the container.
macvlan is not for the faint of heart.
The final statement in the docker-compose.yml file was changed to:
gateway: 192.168.50.1 update if needed
which is the address of the LAN setting in my ASUS RT-AX82U router. It seems perhaps this was the key change to get things working. I am just not sure, everything is blurring together. Even my notes are a mess.
I tried several things and ended up rebuilding the entire SD card from scratch again today...but the docker and Pi-Hole are both working now. Gravity updates and the Pi-hole is blocking network traffic again. Oh Joy!
Things that I tried to solve: Gravity Status: Connection Refused
At the command line I tried : sudo ip link set eth0 promisc on
That did not help on its own.
Then I tried: sudo ip link add macvlan-shim link eth0 type macvlan mode bridge
It did not seem to help with promisc set to on but I left it that way. "It is important to note, that the parent will go into promiscuous mode when a container is attached to the parent since each container has a unique MAC address." a quote from somewhere that ended up in my notes. Even when macvlan mode is not specified it defaults to a bridge configuration.
Then I added: sudo ip addr add 192.168.50.249/28 dev macvlan-shim. I changed the address of the Pi-Hole to see if that changed anything. It did not, so I moved it back to 192.168.50.226
This did not solve the updating the Gravity database issue.
I then changed it to: sudo ip addr add 192.168.50.226/28 dev macvlan-shim
That did not help either. I think the shim helped get the pihole-network talking to the full network but I am not sure.
I then fooled around with the DNS settings and the DHCP service on my ASUS RT-AX82U router. I am not using the DHCP from the Pi-Hole. The final setting is DNS1: 192.168.50.245 and DNS2: 1.1.1.1 in the LAN settings. I went to the WAN settings and manually assigned the same two addresses there.
Then somewhere between numerous reboots of the Pi updating Gravity started working. I wish I had a specific answer what exactly was wrong but I don't. The pihole-network lives happily at 19+2.169.50.245 while the Pi-Hole itself lives at 192.168.50.226. Thats the end result I was looking for.
Next is to get the Plex server running in a Docker. I won't even have the parts for that until the end of the week. I suspect that I will need to change the macvlan statements to something like:
parent: eth0.10 and
parent: eth0.20
I may run out of little grey cells soon!
This is the final version of the docker-compose.yml file I used:
services:
pihole:
networks:
pihole_network:
ipv4_address: '192.168.50.245' update, assign open ip manually
ports:
- "53:53/tcp"
- "53:53/udp"
#- "67:67/udp" # Only required if you are using Pi-hole as your DHCP serv>
- "80:80/tcp"
environment:
TZ: 'America/New_York' # update according to your timezone
WEBPASSWORD: 'password' update password
volumes:
- '/home/username/pihole/etc-pihole:/etc/pihole' update
- '/home/username/pihole/etc-dnsmasq.d:/etc/dnsmasq.d' update
cap_add:
- NET_ADMIN
networks:
pihole_network:
driver: macvlan
driver_opts:
parent: eth0
ipam:
config:
- subnet: 192.168.50.0/24 update if needed
I am not sure but on day three I got it working. Working in this case means the Update Gravity works and the Pi-hole blocks traffic.
THANKS to those who responded and offered advice. I believe the issue was in the macvlan area. I've read a lot and gotten more confused.
