Network Overview shows no devices using pihole
[connected devices should show in network overview]
[no devices show in network overview]
[https://tricorder.pi-hole.net/3v6hh6ieow]
See attached screenshots - running dd-wrt router: DD-WRT v24-sp2 (08/12/10) micro
I'm having the same problem unless I set my Pi-Hole is my DNS server on individual devices.
Do the devices in the network table show up as clients (with the same IP addresses)?
Ummm. Doesn't the screenshot show the ip addresses in the network table? Unless I misunderstand the question.
Yes, the screenshot shows the IP addresses from the network table, but it does not show the clients that Pi-hole has gotten queries from (see the top clients lists on the dashboard).
Ah! you may have stumbled upon what's going on here: I have completely disabled ALL logs. Could that be a reason?
To what extent have you disabled logs? If you've only disabled the log file, then that is no issue (FTL stores the logs in memory). If you've set the privacy level to a level such that client information is not shown, then that will also affect this.
SOLVED:
Disabling all logs disables data in Network overview. Toggling logs on solved the problem, at least for me.
Thanks Mcat12!
