*** [ INITIALIZING ]
[i] 2020-09-23:21:00:09 debug log has been initialized.
[i] Core: v5.1.2 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Remotes: origin https://github.com/pi-hole/pi-hole.git (fetch)
origin https://github.com/pi-hole/pi-hole.git (push)
[i] Branch: master
[i] Commit: v5.1.2-0-g6b536b7
[i] Web: v5.1.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Remotes: origin https://github.com/pi-hole/AdminLTE.git (fetch)
origin https://github.com/pi-hole/AdminLTE.git (push)
[i] Branch: master
[i] Commit: v5.1.1-0-ga03d1bd
[✓] FTL: v5.2
[i] 1.4.53
[i] 7.3.19
[✓] Distro: Raspbian
[✓] Version: 10
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
[✓] armv7l
192.168.1.90/24 matches the IP found in /etc/pihole/setupVars.conf
fe80::7ee6:d20:1697:aa64 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
* Pinging 192.168.1.1...
[✓] Gateway responded.
*:22 sshd (IPv4)
*:22 sshd (IPv6)
[80] is in use by lighttpd
[53] is in use by pihole-FTL
[✓] banner.publisher.to is 0.0.0.0 via localhost (127.0.0.1)
[✓] banner.publisher.to is 0.0.0.0 via Pi-hole (192.168.1.90)
[✓] doubleclick.com is 172.217.168.46 via a remote, public DNS server (8.8.8.8)
[✓] lighttpd daemon is active
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=192.168.1.90/24
IPV6_ADDRESS=
PIHOLE_DNS_1=8.8.8.8
PIHOLE_DNS_2=8.8.4.4
QUERY_LOGGING=true
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=true
BLOCKING_ENABLED=true
[✓] Block page X-Header: X-Pi-hole: A black hole for Internet advertisements.
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
*** [ DIAGNOSING ]: Gravity List and Database
-rw-rw-r-- 1 pihole pihole 5009408 Sep 23 20:55 /etc/pihole/gravity.db
*** [ DIAGNOSING ]: Info table
property value
version 12
updated 1600890944
gravity_count 83408
Last gravity run finished at: Wed 23 Sep 20:55:44 BST 2020
----- First 10 Gravity Domains -----
localhost.localdomain
n2019cov.000webhostapp.com
webmail-who-int.000webhostapp.com
010sec.com
01mspmd5yalky8.com
0byv9mgbn0.com
ns6.0pendns.org
dns.0pengl.com
ios.0pengl.com
0x4fc271.tk
*** [ DIAGNOSING ]: Groups
id enabled name date_added date_modified description
0 1 Default 2020-09-23 20:55:25 2020-09-23 20:55:25 The default group
*** [ DIAGNOSING ]: Clients
*** [ DIAGNOSING ]: Adlists
id enabled group_ids address date_added date_modified comment
1 1 0 https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts 2020-09-23 20:55:25 2020-09-23 20:55:25 Migrated from /etc/pihole/adlists.list
2 1 0 https://mirror1.malwaredomains.com/files/justdomains 2020-09-23 20:55:25 2020-09-23 20:55:25 Migrated from /etc/pihole/adlists.list
-rw-r--r-- 1 root root 46 Sep 23 20:55 /etc/pihole/local.list
192.168.1.90 raspberrypi
192.168.1.90 pi.hole
-rw-r--r-- 1 root root 234 Sep 23 20:55 /etc/pihole/logrotate
/var/log/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-rw-r-- 1 pihole root 15 Sep 23 20:55 /etc/pihole/pihole-FTL.conf
PRIVACYLEVEL=0
-rw-r--r-- 1 root root 1385 Sep 23 20:55 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries
local-ttl=2
log-async
server=8.8.8.8
server=8.8.4.4
interface=eth0
server=/use-application-dns.net/
-rw-r--r-- 1 root root 0 Sep 23 20:55 /etc/lighttpd/external.conf
-rw-r--r-- 1 root root 4066 Sep 23 20:55 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "/pihole/index.php"
server.pid-file = "/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = (
"application/json",
"application/vnd.ms-fontobject",
"application/xml",
"font/eot",
"font/opentype",
"font/otf",
"font/ttf",
"image/bmp",
"image/svg+xml",
"image/vnd.microsoft.icon",
"image/x-icon",
"text/css",
"text/html",
"text/javascript",
"text/plain",
"text/xml"
mimetype.assign = (
".ico" => "image/x-icon",
".jpeg" => "image/jpeg",
".jpg" => "image/jpeg",
".png" => "image/png",
".svg" => "image/svg+xml",
".html" => "text/html; charset=utf-8",
".js" => "text/javascript; charset=utf-8",
".json" => "application/json; charset=utf-8",
".map" => "application/json; charset=utf-8",
".txt" => "text/plain; charset=utf-8",
".eot" => "application/vnd.ms-fontobject",
".otf" => "font/otf",
".ttc" => "font/collection",
".ttf" => "font/ttf",
".woff" => "font/woff",
".woff2" => "font/woff2"
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
"X-Frame-Options" => "DENY"
$HTTP["url"] =~ "\.(eot|otf|tt[cf]|woff2?)$" {
url.access-deny = ("")
expire.url = ( "" => "access plus 0 seconds" )
-rw-r--r-- 1 root root 1755 Sep 23 20:55 /etc/cron.d/pihole
41 3 * * 7 root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updateGravity >/var/log/pihole_updateGravity.log || cat /var/log/pihole_updateGravity.log
00 00 * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker local
46 17 * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 846 Sep 23 21:00 /var/log/lighttpd/error.log
2020-09-23 20:53:57: (server.c.1464) server started (lighttpd/1.4.53)
2020-09-23 20:55:12: (server.c.2059) server stopped by UID = 0 PID = 1
2020-09-23 20:55:13: (server.c.1464) server started (lighttpd/1.4.53)
2020-09-23 21:00:14: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice: Undefined offset: 0 in /var/www/html/pihole/index.php on line 227
2020-09-23 21:00:14: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning: array_key_exists() expects parameter 2 to be array, null given in /var/www/html/pihole/index.php on line 228
-rw-r--r-- 1 pihole pihole 6013 Sep 23 20:55 /var/log/pihole-FTL.log
[2020-09-23 20:55:23.832 13481M] Using log file /var/log/pihole-FTL.log
[2020-09-23 20:55:23.833 13481M] ########## FTL started! ##########
[2020-09-23 20:55:23.833 13481M] FTL branch: master
[2020-09-23 20:55:23.833 13481M] FTL version: v5.2
[2020-09-23 20:55:23.833 13481M] FTL commit: dbd4a69
[2020-09-23 20:55:23.833 13481M] FTL date: 2020-08-09 22:09:43 +0100
[2020-09-23 20:55:23.833 13481M] FTL user: pihole
[2020-09-23 20:55:23.834 13481M] Compiled for armhf (compiled on CI) using arm-linux-gnueabihf-gcc (Debian 6.3.0-18) 6.3.0 20170516
[2020-09-23 20:55:23.834 13481M] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2020-09-23 20:55:23.834 13481M] SOCKET_LISTENING: only local
[2020-09-23 20:55:23.834 13481M] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2020-09-23 20:55:23.834 13481M] MAXDBDAYS: max age for stored queries is 365 days
[2020-09-23 20:55:23.834 13481M] RESOLVE_IPV6: Resolve IPv6 addresses
[2020-09-23 20:55:23.834 13481M] RESOLVE_IPV4: Resolve IPv4 addresses
[2020-09-23 20:55:23.834 13481M] DBINTERVAL: saving to DB file every minute
[2020-09-23 20:55:23.834 13481M] DBFILE: Using /etc/pihole/pihole-FTL.db
[2020-09-23 20:55:23.835 13481M] MAXLOGAGE: Importing up to 24.0 hours of log data
[2020-09-23 20:55:23.835 13481M] PRIVACYLEVEL: Set to 0
[2020-09-23 20:55:23.835 13481M] IGNORE_LOCALHOST: Show queries from localhost
[2020-09-23 20:55:23.835 13481M] BLOCKINGMODE: Null IPs for blocked domains
[2020-09-23 20:55:23.835 13481M] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2020-09-23 20:55:23.835 13481M] DBIMPORT: Importing history from database
[2020-09-23 20:55:23.835 13481M] PIDFILE: Using /run/pihole-FTL.pid
[2020-09-23 20:55:23.835 13481M] PORTFILE: Using /run/pihole-FTL.port
[2020-09-23 20:55:23.835 13481M] SOCKETFILE: Using /run/pihole/FTL.sock
[2020-09-23 20:55:23.836 13481M] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2020-09-23 20:55:23.836 13481M] MACVENDORDB: Using /etc/pihole/macvendor.db
[2020-09-23 20:55:23.836 13481M] GRAVITYDB: Using /etc/pihole/gravity.db
[2020-09-23 20:55:23.836 13481M] PARSE_ARP_CACHE: Active
[2020-09-23 20:55:23.836 13481M] CNAME_DEEP_INSPECT: Active
[2020-09-23 20:55:23.836 13481M] DELAY_STARTUP: No delay requested.
[2020-09-23 20:55:23.836 13481M] NICE: Set process niceness to -10 (default)
[2020-09-23 20:55:23.836 13481M] BLOCK_ESNI: Enabled, blocking _esni.{blocked domain}
[2020-09-23 20:55:23.836 13481M] NAMES_FROM_NETDB: Enabled, trying to get names from network database
[2020-09-23 20:55:23.837 13481M] Finished config file parsing
[2020-09-23 20:55:25.349 13481M] -> Total DNS queries: 0
[2020-09-23 20:55:25.349 13481M] -> Cached DNS queries: 0
[2020-09-23 20:55:25.349 13481M] -> Forwarded DNS queries: 0
[2020-09-23 20:55:25.350 13481M] -> Blocked DNS queries: 0
[2020-09-23 20:55:25.350 13481M] -> Unknown DNS queries: 0
[2020-09-23 20:55:25.350 13481M] -> Unique domains: 0
[2020-09-23 20:55:25.350 13481M] -> Unique clients: 0
[2020-09-23 20:55:25.350 13481M] -> Known forward destinations: 0
[2020-09-23 20:55:25.350 13481M] Successfully accessed setupVars.conf
[2020-09-23 20:55:25.361 13483M] PID of FTL process: 13483
[2020-09-23 20:55:25.363 13483/T13484] Listening on port 4711 for incoming IPv4 telnet connections
[2020-09-23 20:55:25.364 13483/T13486] Listening on Unix socket
[2020-09-23 20:55:25.368 13483/T13485] Listening on port 4711 for incoming IPv6 telnet connections
[2020-09-23 20:55:25.369 13483M] Reloading DNS cache
[2020-09-23 20:55:25.369 13483M] Blocking status is enabled
[2020-09-23 20:55:25.436 13483M] gravityDB_open(): /etc/pihole/gravity.db does not exist
[2020-09-23 20:55:25.436 13483M] gravityDB_count(0): Gravity database not available
[2020-09-23 20:55:25.437 13483M] gravityDB_count(3): Gravity database not available
[2020-09-23 20:55:25.437 13483M] WARN: Database query failed, assuming there are no blacklist regex entries
[2020-09-23 20:55:25.437 13483M] gravityDB_open(): /etc/pihole/gravity.db does not exist
[2020-09-23 20:55:25.437 13483M] gravityDB_count(4): Gravity database not available
[2020-09-23 20:55:25.437 13483M] WARN: Database query failed, assuming there are no whitelist regex entries
[2020-09-23 20:55:25.437 13483M] Compiled 0 whitelist and 0 blacklist regex filters for 0 clients in 0.6 msec
[2020-09-23 20:55:48.090 13483M] Reloading DNS cache
[2020-09-23 20:55:48.091 13483M] Blocking status is enabled
[2020-09-23 20:55:48.156 13483M] INFO: No regex blacklist entries found
[2020-09-23 20:55:48.157 13483M] INFO: No regex whitelist entries found
[2020-09-23 20:55:48.157 13483M] Compiled 0 whitelist and 0 blacklist regex filters for 0 clients in 1.6 msec
[2020-09-23 20:55:48.357 13483M] Reloading DNS cache
[2020-09-23 20:55:48.358 13483M] Blocking status is enabled
[2020-09-23 20:55:48.411 13483M] INFO: No regex blacklist entries found
[2020-09-23 20:55:48.412 13483M] INFO: No regex whitelist entries found
[2020-09-23 20:55:48.412 13483M] Compiled 0 whitelist and 0 blacklist regex filters for 0 clients in 2.4 msec
*** [ DIAGNOSING ]: contents of /dev/shm
-rw------- 1 pihole pihole 323584 Sep 23 20:55 /dev/shm/FTL-clients
-rw------- 1 pihole pihole 144 Sep 23 20:55 /dev/shm/FTL-counters
-rw------- 1 pihole pihole 4096 Sep 23 20:55 /dev/shm/FTL-dns-cache
-rw------- 1 pihole pihole 65536 Sep 23 20:55 /dev/shm/FTL-domains
-rw------- 1 pihole pihole 28 Sep 23 20:55 /dev/shm/FTL-lock
-rw------- 1 pihole pihole 77824 Sep 23 20:55 /dev/shm/FTL-overTime
-rw------- 1 pihole pihole 4096 Sep 23 20:55 /dev/shm/FTL-per-client-regex
-rw------- 1 pihole pihole 229376 Sep 23 20:55 /dev/shm/FTL-queries
-rw------- 1 pihole pihole 12 Sep 23 20:55 /dev/shm/FTL-settings
-rw------- 1 pihole pihole 4096 Sep 23 21:00 /dev/shm/FTL-strings
-rw------- 1 pihole pihole 20480 Sep 23 20:55 /dev/shm/FTL-upstreams
*** [ DIAGNOSING ]: Locale
LANG=en_GB.UTF-8
-rw-r--r-- 1 pihole pihole 1564 Sep 23 21:00 /var/log/pihole.log
-----head of pihole.log------
Sep 23 20:55:25 dnsmasq[13483]: started, version pi-hole-2.81 cachesize 10000
Sep 23 20:55:25 dnsmasq[13483]: compile time options: IPv6 GNU-getopt no-DBus no-UBus no-i18n IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset auth DNSSEC loop-detect inotify dumpfile
Sep 23 20:55:25 dnsmasq[13483]: using only locally-known addresses for domain use-application-dns.net
Sep 23 20:55:25 dnsmasq[13483]: using nameserver 8.8.4.4#53
Sep 23 20:55:25 dnsmasq[13483]: using nameserver 8.8.8.8#53
Sep 23 20:55:25 dnsmasq[13483]: read /etc/hosts - 5 addresses
Sep 23 20:55:25 dnsmasq[13483]: failed to load names from /etc/pihole/custom.list: No such file or directory
Sep 23 20:55:25 dnsmasq[13483]: failed to load names from /etc/pihole/local.list: No such file or directory
Sep 23 20:55:48 dnsmasq[13483]: read /etc/hosts - 5 addresses
Sep 23 20:55:48 dnsmasq[13483]: failed to load names from /etc/pihole/custom.list: No such file or directory
Sep 23 20:55:48 dnsmasq[13483]: read /etc/pihole/local.list - 2 addresses
Sep 23 21:00:13 dnsmasq[13483]: query[A] banner.publisher.to from 127.0.0.1
Sep 23 21:00:13 dnsmasq[13483]: gravity blocked banner.publisher.to is 0.0.0.0
Sep 23 21:00:13 dnsmasq[13483]: query[A] banner.publisher.to from 192.168.1.90
