So you may see a similar post, but I didn't update it, so I needed to create a new one. I just accidentally press the Netflix button, and wouldn't you guess it just booted right up, with all of the following blocked!
Bold domains are the permitted, rest are red or blocked. As stated in my earlier post, I did not want to post the local logs as it was pertaining to specific domains. Because they are visibly unique, I blocked out (I hope) enough information to keep it private to not give away sensitive info. I mean the timing of the logs etc would probably be more than enough for figuring out the originating
Bolded domains cannot be inside code blocks:
ipv4-c###-xxx###-ix.1.oca.nflxvideo.net 172.21.72.42 OK (answered by
localhost#5335)
So, I am not sure that any of this is being seen by the devs at the service mentioned, surely they aren't reading this, but maybe they are seeing activity get through with a lot of other activity not getting through, and quietly changing it in the background. It would be very intriguing if we could get someone else to use my same blocklist (just look at all those blocked domains!) and get a similar reuslt. I didn't try streaming a video as I didn't realize I started the program, and was, again, surprised to see it working a second time around.
If anyone would like to test this and share your results, I'd be very grateful. It goes to show just how much you DON'T need connecting, and what I hope doesn't happen, is that the service just conglomerates all the domains. Then you really can't stop things like "customer events" which while probably very helpful to the operators, I feel a bit invasive.
AAAA images.sr.roku.com 172.21.72.42 Blocked
(exact blacklist) IP (0.0ms)
(exact blacklist) IP (0.7ms)
(exact blacklist) IP (1.2ms)
(exact blacklist) IP (0.4ms)
A cdn-0.nflximg.com 172.21.72.42 Blocked (gravity) IP (0.1ms)
A cdn-0.nflximg.com 172.21.72.42 Blocked (gravity) IP (0.0ms)
AAAA scribe.logs.roku.com 172.21.72.42 Blocked (gravity) IP (0.2ms)
AAAA scribe.logs.roku.com 172.21.72.42 Blocked (gravity) IP (0.5ms)
A scribe.logs.roku.com 172.21.72.42 Blocked (gravity) IP (0.0ms)
AAAA scribe.logs.roku.com 172.21.72.42 Blocked (gravity) IP (0.0ms)
A ichnaea.netflix.com 172.21.72.42 Blocked
(exact blacklist) IP (0.1ms)
A nrdp50-appboot.netflix.com 172.21.72.42 Blocked (gravity) IP (2.3ms)
A nrdp50-appboot.netflix.com 172.21.72.42 Blocked (gravity) IP (0.1ms)
A ipv4-c###-xxx###-ix.1.oca.nflxvideo.net 172.21.72.42 OK (answered by
localhost#5335) IP ( ms)
A ipv4-c###-xxx###-ix.1.oca.nflxvideo.net 172.21.72.42 OK (sent to
localhost#5335) N/A
A nrdp51-appboot.netflix.com 172.21.72.42 Blocked (gravity) IP (1.3ms)
A nrdp51-appboot.netflix.com 172.21.72.42 Blocked (gravity) IP (0.0ms)
AAAA scribe.logs.roku.com 172.21.72.42 Blocked (gravity) IP (1.1ms)
A scribe.logs.roku.com 172.21.72.42 Blocked (gravity) IP (2.3ms)
A scribe.logs.roku.com 172.21.72.42 Blocked (gravity) IP (0.1ms)
A preapp.prod.partner.netflix.net 172.21.72.42 Blocked
A **ipv4-x###-xxx###-ix.1.oca.nflxvideo.net** 172.21.72.42 OK (answered by
localhost#5335) IP (0.7ms)
A **ipv4-x###-xxx###-ix.1.oca.nflxvideo.net** 172.21.72.42 OK (sent to
localhost#5335) N/A
localhost#5335) IP (0.4ms)
A ipv4-x###-xxx###-ix.1.oca.nflxvideo.net 172.21.72.42 OK (sent to
localhost#5335) N/A
A occ-0-1328-1327.1.nflxso.net 172.21.72.42 Blocked
(exact blacklist) IP (0.5ms)
A uiboot.netflix.com 172.21.72.42 Blocked (gravity) IP (0.3ms)
A uiboot.netflix.com 172.21.72.42 Blocked (gravity) IP (0.1ms)
AAAA api.roku.com 172.21.72.42 Blocked (gravity) IP (0.6ms)
AAAA api.roku.com 172.21.72.42 Blocked (gravity) IP (1.3ms)
A api.roku.com 172.21.72.42 Blocked (gravity) IP (0.0ms)
A api.roku.com 172.21.72.42 Blocked (gravity) IP (0.3ms)
AAAA push.prod.netflix.com 172.21.72.42 Blocked
A cdn-0.nflximg.com 172.21.72.42 Blocked (gravity) IP (1.8ms)
A api-global.netflix.com 172.21.72.42 Blocked
(exact blacklist) IP (2.1ms)
A nrdp.prod.cloud.netflix.com 172.21.72.42 Blocked
(exact blacklist) IP (0.6ms)
(exact blacklist) IP (0.2ms)
AAAA amoeba-plus.web.roku.com 172.21.72.42 Blocked
(exact blacklist) IP (0.3ms)
(exact blacklist) IP (1.1ms)
(exact blacklist) IP (1.0ms)
A nrdp50-appboot.netflix.com 172.21.72.42 Blocked (gravity) IP (0.3ms)
A nrdp50-appboot.netflix.com 172.21.72.42 Blocked (gravity) IP (0.2ms)
AAAA roku.adsmeasurement.com 172.21.72.42 Blocked
(exact blacklist) IP (0.9ms)
A nrdp.prod.ftl.netflix.com 172.21.72.42 Blocked
A cdn-0.nflximg.com 172.21.72.42 Blocked (gravity) IP (5.8ms)
A customerevents.netflix.com 172.21.72.42 Blocked
A uiboot.netflix.com 172.21.72.42 Blocked (gravity) IP (0.8ms)
A uiboot.netflix.com 172.21.72.42 Blocked (gravity) IP (2.5ms)
A secure.netflix.com 172.21.72.42 Blocked (gravity) IP (0.1ms)
A secure.netflix.com 172.21.72.42 Blocked (gravity) IP (0.3ms)
A nrdp.nccp.netflix.com 172.21.72.42 Blocked (gravity) IP (0.0ms)
A nrdp.nccp.netflix.com 172.21.72.42 Blocked (gravity) IP (0.3ms)
A nrdp51-appboot.netflix.com 172.21.72.42 Blocked (gravity) IP (0.1ms)
A nrdp51-appboot.netflix.com 172.21.72.42 Blocked (gravity) IP (16.6ms)
AAAA ravm.tv 172.21.72.42 Blocked (gravity) IP (1.2ms)
AAAA ravm.tv 172.21.72.42 Blocked (gravity) IP (1.0ms)
A ravm.tv 172.21.72.42 Blocked (gravity) IP (0.8ms)
A ravm.tv 172.21.72.42 Blocked (gravity) IP (9.6ms)
AAAA scribe.logs.roku.com 172.21.72.42 Blocked (gravity) IP (0.1ms)
AAAA api2.sr.roku.com 172.21.72.42 Blocked (gravity) IP (0.1ms)
AAAA api2.sr.roku.com 172.21.72.42 Blocked (gravity) IP (1.2ms)
A api2.sr.roku.com 172.21.72.42 Blocked (gravity) IP (0.5ms)
AAAA securepubads.g.doubleclick.net 172.21.72.42 Blocked (gravity) IP (0.5ms)
AAAA securepubads.g.doubleclick.net 172.21.72.42 Blocked (gravity) IP (0.4ms)
