Installed unbound with the help of pihole documentation guide. but unbound fails to load or trust the anchor at boot. I have to run it then restart the service every boot to enable it
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sun Sep 27 08:48:15 2020
pi@raspberrypi:~ $ systemctl status unbound
Active: active (running) since Sun 2020-09-27 08:48:11 +0545; 50s ago
Docs: man:unbound(8)
Process: 500 ExecStartPre=/usr/lib/unbound/package-helper chroot_setup (code=exited, status=0/SUCCESS)
Process: 541 ExecStartPre=/usr/lib/unbound/package-helper root_trust_anchor_update (code=exited, status=0/SUCCESS)
Main PID: 571 (unbound)
Tasks: 1 (limit: 2065)
CGroup: /system.slice/unbound.service
└─571 /usr/sbin/unbound -d
Sep 27 08:48:10 raspberrypi systemd[1]: Starting Unbound DNS server...
Sep 27 08:48:11 raspberrypi package-helper[541]: /var/lib/unbound/root.key has content
Sep 27 08:48:11 raspberrypi package-helper[541]: fail: the anchor is NOT ok and could not be fixed
Sep 27 08:48:11 raspberrypi unbound[571]: [571:0] info: start of service (unbound 1.9.0).
Sep 27 08:48:11 raspberrypi systemd[1]: Started Unbound DNS server.
pi@raspberrypi:~ $ sudo unbound-anchor
pi@raspberrypi:~ $ sudo service unbound restart
Active: active (running) since Sun 2020-09-27 08:49:30 +0545; 19s ago
Process: 857 ExecStartPre=/usr/lib/unbound/package-helper chroot_setup (code=exited, status=0/SUCCESS)
Process: 860 ExecStartPre=/usr/lib/unbound/package-helper root_trust_anchor_update (code=exited, status=0/SUCCESS)
Main PID: 864 (unbound)
└─864 /usr/sbin/unbound -d
Sep 27 08:49:29 raspberrypi systemd[1]: Starting Unbound DNS server...
Sep 27 08:49:30 raspberrypi package-helper[860]: /var/lib/unbound/root.key has content
Sep 27 08:49:30 raspberrypi package-helper[860]: success: the anchor is ok
Sep 27 08:49:30 raspberrypi unbound[864]: [864:0] info: start of service (unbound 1.9.0).
Sep 27 08:49:30 raspberrypi systemd[1]: Started Unbound DNS server.
pi@raspberrypi:~ $
Unbound should work with the anchor
N/A
